Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Dishwasher stopped working full of water
Removed sides drained by lifting micro switch
unblocked vent on fill and drain tank
but it still will not work
the timer seems to be working and i can here things clicking but the machine does not go. how do get in to see the controls
  • robbiemac472 Jul 06, 2008
    will check that cheers
    President:
  • 1,462 Answers
Sounds like sticking in cycle hence not advancing thro to drain.
there can be more than one cause. for a start, check heater and thermal cutout in series with heater. check also that the main pump is ok. after you have run it a while, check if main pump is warm to the touch even if not rotating. if this is the case, then fault can be with the pump capacitor - a cheap part and easily repleced
Posted on Jul 06, 2008
CHH50 Dishwasher getting back flow through the rinse tubing and the filling container when machine is switched off
Most dishwashers require a DRAIN VENT between the drain hose and the connection to your drain plumbing. If there is no drain vent, water from your sink drain can easily flow into the dishwasher. If you do not have a drain vent, install one. If you have one, make sure that the vent hole is not obstructed in any way.
May 11, 2015 | Dishwashers
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Dishmachine will not hold water. Its draining as you fill it?
0
Does not hold water Faulty #3 micro switch (drain) Replace switch, P/N 00411.00
Clogged or defective drain valve Clean and/ or replace drain valve, P/N 04113.00
Nov 11, 2011 | Cma Dishmachines L-1X Dishwasher
GET 0E CODE SHOWING ON MY LG DISHWASHER
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
if that doesnt help you.....
the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Aug 28, 2010 | Dishwashers
I have a Beko DE 2541F Slimline Dishwasher and it fills and empties the water but the cycle does not start. The water does not get to the spray arms. I have tried on pre wash cycle as well so I do not...
If there are no problems of drain valve stuck, then the problem with the micro controller board.
When the water is full in the tank, the wash cycle will start with the spray arm in action. Lastly block the drain hose and see. Here water full will be detected & the machine will start if the level sensor is OK .
If m/c works here, you have to check the Solinoid valve of the drain.
Otherwise the micro controller.
For this pl take the help of the service provider as lot of programming versions are there. Some may suit or may not. If we try the will not accept after selling the board to u.
Apr 07, 2010 | Beko 24 in. D3731F Free-standing...
2in.of water standing in bottom when finished
Most likely a clog, either along the drain hose, or more likely, actually in the air gap vent. Disconnect the drain hose from the dishwasher and place a bucket under it. Run the drain cycle. This should clear any clog along the drain line. Remove the air gap vent from the top of the sink and disconnect the other hose. Remove the small cap at the top of the vent by pressing the small clips on opposite sides of each other and lift the cap out. Using either a strong flow of water, or, a thin, long-blade screwdriver, remove any debris from the two hose connectors. (Problem is most likely in the smaller hose connector which is preventing water from flowing over to the other connector to drain out). So, during operation, water goes up the small drain hose, but can't go any further and water remains in the dishwasher.
Clearing the air vent cap/filter should solve your problem.
Mar 20, 2010 | Bosch Evolution 500 SHE55M06UC 24 in...
Dishlex dishwasher has flashing eco light and won't stop draining
you need to remove the bottom panel under the door, under the machine you will find a small cup on an arm attched to a micro switch this cup is for an over flow ie when the fill setting is incorrect or when the wrong detergent is used ie to many suds empty this cup, thsi should solve your problem
Sep 04, 2009 | Dishwashers
Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Sep 17, 2008 | Siemens 24 in. SL34A006UC Built-in...
Am14 initial fill
lift **** basket out and lift out samle stailees plate drain and look for stailess probe coming out of side of tank half way down there should be a white pprobably yellowed plastic ball it is a float they get old and fill fith water and don't flote telling maching I have no water keep the water coming. the float is sometimes even missing fell off andf thrown out. 10 bucks and a clip your off and running. call hobart its 110.00 and your off and running.
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Bosch Dishwasher SHV4313GB/17 Wont switch off ! The machine keeps running even when you open the door The pump is trying to drain water away (even though there is no water left in machine ) Have tried to...
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Mar 08, 2008 | Dishwashers
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
436 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
