Question about Whirlpool Calypso GVW9959K Top Load Washer
Doesnt drain Calypso GVW9959Kq2 starts to spin, then stops, because it doesnt drain, I have taken it apart already, cleaned it out, pump looks good, hoses looks good, i dont know what the problem is. I ran the diagnostics and now i get the ob error code with nothing in it. The machine stopped working aprox. 7-8 month ago. Now it makes a high pitch buzzing noise.
  • vinsandy2000 Jul 10, 2008
    I have checked the hot and cold hoses, and the drain hose - found some pocket change- thought this would solve the problem but water keeps spilling out from the cylinder, and then I get the ob symbol.
  • Anonymous Jul 10, 2008
    yes, and the fabric softner has not been distributed.
Spidpiglovme is a ****
Posted on Jul 17, 2008
    Problem Solver:
  • 15 Answers
Chin Sao mua te quempo
Posted on Jul 13, 2008
The water does not drain , the washer sometimes spins and does a fine jobbut only occasionally. I have tried only putting in a small load this worked one time. I have cleaned out the drain lower right and...
Hi Karyn.
I understood that you already checked the drain filter at the front bottom.
If you haven't done it yet check also drain hose at the back. Make sure that setting is as from manual. it should be 33 inches, check also height, connection and check that is not kinked. If the drain hose is set incorrectly you get water siphoning back to the drain pump and machine does not drain. For settings see your owners manual or pages 9/10 of the service manual below.
If the drain hose is OK, then the drain pump and the control module must be tested.
Disconnect the drain pump and measure the resistance at the connector. Impedance must be between 140 and 200 Ohms. Replace the drain pump if it is faulty.
Check the voltage out from central control unit to drain pump when pump is energized. If there is not voltage, replace the central control unit.
Also have a look at the pressure switch. The pressure switch determines when to start/stop the drain pump and when to advance to rinse.The pressure switch is located in control assembly. Clean the hose connected to the pressure switch. The switch is difficult to test. Replace the switch if pump and volts at control unit are OK.
Here the part.
Ohms reading is done with power not connected. Testing with power on must be done by a trained person.
Here a service manual covering different models.
Regards.
Ginko
Nov 07, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool calypso washing machine
if it stops and starts it coule be a power board problem
Jun 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso behaving badly
Did you remove the tub ring and wash plate?  A lot of times there will be lint and other foreign objects lodged in the drain opening between the tub and the pump.  You have to remove the wash plate in order to get to it, however.  The most common item found are the wire hoops from under support bras.  The wire make it's way between the tub and basket and gets lodged in the drain line.  Eventually lint and debris starts to collect and you end up with a long drain error.  Post back with comments and let me know if you've already done this.  If not, it might be worth the effort to take a look.  If you need instructions on how to get the tub ring and wash plate out, let me know.
Oct 13, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Won't spin or drain
most of the time wen this happens ther is a foreign object stopping the drain pump from working.if you still have water in the tub use a shop vac attach it to the drain hose to **** out all the water then pull the hoses of the drain pump and look inside for something stopping the pump if there is nothing found replace the drain pump
Sep 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Calypso washer won't spin and drain properly
i've pulled stuf from many a calypso pump and its not the funest pump to clean.some designs never get stuff in the pump others its like theres a sock magnet in there or somthing.your has got a sock magnet.take off the frount and you will see the pump on the right.white,it has two hoses.take the inlet off first if eazyest then will only have to take one hose.you can geter done.God bless,tom
Jan 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
438 people viewed this question
Dan Webster
Dan Webster
Sal De
