HUMMING/CHATTERING NOISE ON SANYO TV
HUMMING/CHATTERING NOISE WHEN TV TURNED ON. SOUND SUBSIDES WHEN PRESSURE APPLIED TO TOP OF COMPONENT. IS THIS A RELAY ISSUE.
TROUBLESHOOT TO COMPONENT:
MODEL: SANYO AVM-1903
TYPE DH1U
12VDC
TV-5
DEC
YOUR ASSISTANCE IS APPRECIATE.
THX,
KEN ROEBUCK
KEN@KENROEBUCK.COM
MODEL: SANYO DS19350
BEFORE SEEING THIS SITE, I TROUBLESHOOT MY SELF AND SUSPECTED RELAY "TYPE DH1U 12VDC TV-5 DEC".
MY QUESTION IS CHANGING THIS RELAY WILL FIX THIS PROBLEM OR SOME OTHER COMPONENTS CAUSING THIS RELAY TO FAIL.
  • NBTAMIL Mar 23, 2009
    Excellent, thank you both Lee2fixit's and OldishFella,
    I know that, it is some AC leak through DC coil that is why chatterring was occuring, but I was not sure which cap is leaking.
    I am kind of busy w/ my kids now. After I fix my TV i will post my result.
    Thanks again.
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Posted on Mar 05, 2009
  • 218 Answers
I got a 13" Sanyo AVM-1304 with the same problem today. Found The picture and sound were okay, but the relay chatter was very loud. Found a couple of notes on other forums saying that changing the filter capacitor would fix it. (On that model it was C022, a 470MF 25VDC electrolytic cap). I changed it about an hour ago and so far so good.
Posted on Jul 06, 2008
  • 1 more comment
  • Lee2fixit Jul 06, 2008
    Next day - still working like a champ. Set has been on for about 6 hours with no further buzzing/chattering noise from the relay. I didn't mention it before, but this problem started after the set had sat unused (plugged in, but not watched) for several months. Guess the capacitor continued to age while it sat, but the noise didn't appear until the relay was called on. Your unit might have a different component number or rating - look for a small filter cap right next to the relay.
  • Lee2fixit Feb 15, 2009
    Just an update.... after 6 months, the fix is still good. It was definitely a bad capacitor causing the relay to buzz loudly. The replacement capacitor cost $1.59.
    Just an update... after 6 months the fix is still good. Replacing that $1.59 capacitor saved this set from the trash heap!
I had the same problem with a ds25390 board. it was a 470@25v (replaced with 470@35v costing $1.25) at location c622 and an A1015y (crosses to a 2sa1015y) transistor ($1.75) at location q623. if you look at the schmo (http://elektrotanya.com/sanyo_ds25390-ctv.pdf/download.html) you will see the cap filters a/c from the coil of the relay. the transistor provides the switching to turn the relay on. while the transistor might have not been bad, it showed as an base/collector open. i replaced it anyway as the a/c would have hit the collector of the A1015y and its a $1.75 part.
Posted on Jan 10, 2013
    Guru:
  • 415 Answers
I detected the noise from the relay and replaced the relay with a substitute purchased from Radio Shack < $10.00. The buzz / chatter noise continued. I read other posts and decided to try replacing the capacitor. Mine was a 25v / 470uf. Radio Shack had a 35v / 470uf for <$2.00. I installed the new capacitor and the t.v. is working GREAT! I could not have done this repair without the help of FixYa Community. Thanks!!!!!!
Posted on Feb 06, 2010
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
After unit is on for about 15 minutes it clicks into a buzzing noise & when turned off pops. if i leave it off for about 45 minutes it works again for about 15 minutes, but if i turn it off & back...
It seems like some component(s) become over heated by the time. It could be caused by either some faulty component(I guess Capacitor or Transistor in which case they must be replaced) or bad heat transfer(radiator, mounted on power transistors) that must be resoldered and/or screws/clips must be tightened.
Good luck
SciPhinx
May 11, 2010 | Pioneer VSX-D411 Receiver
2005 hyundai accent is making a chattering sound
Depending on the quality of pad used you may get some noise from the brakes mainly squeaks. Grinding or chattering is unusual though. Id take it back to the place that installed the pads/shoes and have them check it out again. Do you get a vibration while braking?
Jan 07, 2010 | 2005 Hyundai Accent
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Loud humming noise
this problem is sif coil & sound releted 5.5 crustal &releted pf try this
Jun 21, 2008 | Sanyo DS19330 19" TV
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Televison & Video Logo
1,804 people viewed this question
Top Televison & Video Experts
Electro Med Services...
