You made the decision, Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
SOURCE: minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
SOURCE: Minolta Di450 service code reset service code
di450 . what is the solution of this code 1326?
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
