Sont tv I have a sony bravia 40 inch lcd KLV-40U100M and it would always turn off by itself then turn back on. That went on for a long time but now the tv doesn't even turn on, I know this is a very common problem with this model tv. I was just wondering what my best approachto fix it would be
    Scholar:
  • 83 Answers
According to the owners manual (toubleshooting section page 42)
  1. The unit turns off automactically - Check if sleep timer is activated (page 31,40).
  2. No picture - Check Power Saving settings (page 41).
If there is no power at all, please do not try to fix yourself. Please contact a qualified service technician to do it or call Sony
in the USA 1-800-222-7669 - The Direct Response Center.
In Canada call 1-899-7669 - Customer Relations Center
Here is the manual just in case you don't have it.
You will need PDF software to read it.
I HOPE THIS HELPS YOU!
GOOD LUCK!
Posted on Jul 05, 2008
  • 2,071 Answers
Your problem is in the power supply.Bad regulation of the incoming voltage could cause this issue although,to be frank so could 10 others but we have start somewhere. There is a capacitor across the incoming line neutral. It can be a dry up or leaky cause the problem, change it out with one of identical rating i would probably also check the flyback circuit and flyback transformer although now you are getting into a dangerous area especially if u have electronic experience find a technician to do the works in order to avoid high voltage shock or bring your t.v in repair shop. find a good one you were probably have to pay $52 up tell the guider that the problem is power supply and flyback.
    Brigadier General:
  • 3,614 Answers
i want to to know if there is any LED indicators flashes like; timer/standby light is flashes constatntly..?
Let me know...
Thank you
micromaster
How to connect antenna to klv 40u100m
Correct. You have to connect the antenna to another box and then take the output of that box to the TV. An old VCR is ideal as this box.
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
How do you remove base from Sony Bravia KLV-40u100m
First remove the back panel from the set. Next look at the bottom and you'll see an aluminum bracket that connects the base to the frame of the set. Remove the four screws, replace the back and you're done.
Sep 06, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
My Sony Bravia KLV-40U100M has audio but the screen is black. No picture. Could it be the lamp? The unit is only a little over 2 years old
No,this tv a LCD not a DLP.The LCD inverter board is dead.Must replaced to get picture back.The board is usally a long board.Tries Shopjimmy.com,Ebay.com to buy the board.
Jan 15, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
There is no picture and no sound on my sony bravia KLV-40u100m
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Jan 01, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Tv don't turn on at all!
The U series has two boards and it could be either the system/video board or the power supply board. It will take a tech to tell you which is bad
Oct 17, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Set up a channel ( 2,7,8,9,10,sbs ) on TV sony LCD
If you want to set up tv channels in your tv, connect antenna cable in RF Input at rear of tv, go to tv menu and select preset, then press auto-preset and rest will do tv itself.
Sep 18, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony BRAVIA KLV-40U100M Issue
Just bought the KLV-40U400M Sony Bravia Monitor. Did you fix the turn on turn off problem? How much did it cost, labor/parts?
I'm thinking I better get the extended warranty although I wonder if the board will continue to go bad year after year.
I was told the tv could be replaced but w/someone else's refurbished tv. I was very unhappy w/that response.
So how's your tv today?
-Capri
Nov 03, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
