Question about GE JBP90 Electric Kitchen Range
Oven will not stay on when baking regular none at all, convection have to set a couple of times
When turning oven on both regular baking & sometimes convection baking, oven will start to heat up & then quit working. Regular baking will not work at all now, have to reset covection baking sometimes as much as ten times before oven will stay on and work.
  • 1 more comment
  • Anonymous Sep 29, 2008
    Same type problem...appears to start heating up in all modes (bake, convection, broil), but less than a minute later it shuts down. No code on the panel and it will let you restart the cycle only to shut down again. Range seems to work fine. Have cleaned up connections but still doesn't work...
  • Anonymous Feb 18, 2009
    my convection shuts off and on before completing the baking. what is wrong.
  • Anonymous Apr 12, 2009
    GE Oven CGS980 will not stay on once it reaches convection temperature. Must turn off and back on for it to reach the correct temp. Will keep turning off every time it reaches commanded temp.
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Posted on Dec 08, 2008
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
Nov 25, 2010 | Viking 30" Professional Select Built-in...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Convection fan doesn't turn on
Found this site cuz I had the same problem- as your purchase was 4 years ago- not sure that I'll help you... But help others who are stumped... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Nov 18, 2008 | Frigidaire Gallery 30" Self-Cleaning...
I have a built-in GE electric convection-regular oven. Model JT915W0F8WW. I don't understand when I push the convection baking do I change the baking time? Isn't it suppose to bake faster than the...
As a genaral rule of thumb.. Most recipes can be adjusted for convection oven use by decreasing the temperature by 25 degrees F and decreasing cooking time about 25%. Dishes with cooking times over 45 minutes, and that might dry out too much (like lasagna, or meatloaf) you should cover for the first half of the cooking time, and then remove the cover.
Aug 31, 2008 | GE Kitchen Ranges
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
GE JBP90 Electric Kitchen Range Logo
661 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
