Question about HP PSC 2210 All-In-One InkJet Printer
Carriage jammed When I was printing each time the printer carriage did a "return" it made an awful screeching noise.  I was running over to cancel the print job when it stopped on it's own.  Now I have an error message that says "open the door, clear carriage jam and press enter"  I lifted up the top and the carriage is all the way to the right so i cannot see it.  i opened the back and can't get it it there either. Help:)
  • 61 Answers
First open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Posted on Jul 24, 2008
Kodak esp 2170 carriage jam problems
The carriage operation is not synchronized. It will have to be adjusted to normal
Aug 14, 2016 | Kodak ESP Office 2170 All-in-One Printer
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
My brother printer mfc-j415w keeps giving me an error message which says paper jammed, I removed all paper and bits of debris found in between the rollers but it still keeps giving me the same error m
there will be paper to the side of the printer which is stopping the carriage from travelling fully which will also be why it makes a noise.
If its to the right of the carriage, start printer and when carriage starts to move pull the power lead, you'll be able to move the carriage out of the way and look in with a torch to find the paper or foreign object. Just remove it and restart the printer and everything will be normal.
Please indicate if it fixed your problem here.
If you need ink for this printer go to our site:
http://www.the-inkstore.co.uk
Jan 29, 2013 | Office Equipment & Supplies
Carriage jam error
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website http://www.the-inkstore.co.uk/frame/pages/epson.htm
Regards
Aeronautical
Oct 25, 2012 | HP OfficeJet 6110 All-In-One InkJet...
When turn on typewriter there is an continuous beeping/screeching noise and will not operate.
Remove print wheel to ensure its not jamming, switch machine back on and see if carriage returns to the LHS home position. If it does not and the carriage is just shaking and the noise is still there, you may have a defective carriage motor or defective power supply.
May 27, 2010 | Nakajima AE-830 Typewriter
13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Jun 23, 2009 | HP LaserJet 4200 Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
