I have a Maxtor 6Y120Lo internal hard drive which is my "C" drive it is nearly full Can I add another hard drive and double my "C" drive
    New Friend:
  • 57 Answers
Your C drive is the heart of your data. That will be where your operating system and program files will be located. If you want to store more data, adding another drive will work just fine, internal or external. The letter will be different so you can tell where your program files are and where your personal files are. If you need more space for programs you will want to change out your C drive for a bigger hard drive.
Posted on May 26, 2014
    President:
  • 1,314 Answers
You can add another hard drive, but it won't double your C drive; it will just show up as another hard drive.
However, using a program like Acronis, you can hook up the 2nd hard drive, make an exact image of your c drive on the new drive, then connect the new drive in the old drive's place and there you have added more space on your c drive as it will automatically become the c drive.
Posted on Jul 05, 2008
My maxtor external hard drive gives a beep sound when I plug it to my computer. The computer says "a new external hard is added to your compute"r but when I click on MY COMPUTER, it doen't...
1) click start
2) right click on "computer" or "my computer"
3) click manage
4) IF you get a user account control popup click yes
5) double click on storage
6) double click on disk management
7) identify your disk, it should be empty and most likely named "disk 1" or maxtor drive or something
8) right click on it and select format (quick format, default allocation size, NTFS)
9) voila!
-Luke
Jul 21, 2011 | Maxtor Hard Drive
Hello, I would like to recovery the movies who are saved on the Maxtor Diamond max 16 QuickVIEW. This hard drive was in a dead JVC video recorder. My iMac say:" this disc is unreadable on this...
Video recorders use a different format technique than PC"S.When you take out the drive from recorder you have to wipe it clean and reformat it in a format compatible with normal PC's. That is why it will not work with a mac or a PC.
Sep 03, 2017 | Maxtor QuickView (6K040T0) Hard Drive
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
Aug 08, 2010 | Maxtor Hard Drive
I have just been given a Maxtor 750gb separate hard drive but it has no power adaptor. Would i be able to use an adaptor from my 500gb Maxtor separate hard drive or will i have to purchase a new power...
By SEPARATE I am taking that to mean an external drive and not an internal mounted drive. If IT IS external the same power supply should work fine as the drive motors are the same in both models. IF IT IS Internal then the question is whether your power supply is molex or ATA.
Jun 06, 2010 | Maxtor Hard Drive
Hard Drive: I have a Maxtor model #90913D4 and need to know ho...
The Maxtor 90913D4 internal 7200 RPM hard drive can be connected via IDE, its a 9.1 GB drive with 512 KB of cache.
May 10, 2010 | Ximeta Hard Drive
My external hard drive is 300g,i formatted my internal hard drive and found that my external drive was also formatted and was only 3g.could someone help me please that's a lot of space lost
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Auto Play
* Click Start
* Click Run
* Enter GPEDIT.MSC
Group Policy mmc will popup. On left panel:
* Double-click Computer Configuration to open submenu
* Double-click Administrative Templates to open submenu
* Double-click System to open submenu
* Double-click Turn autoplay off option which will be near the bottom of the list in the right panel.
The default is the Not configured. Set it to Enabled."
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
MAXTOR HARD DRIVE
Go to "My Computer".
Right click your drive and select properties.
click the "security" tab.
select one by one and click "remove" for each user.
When all users have been deleted, click on add.
Under the "Enter the object names to select", type "everyone"; click OK.
now, under "Permissions for Everyone", click the check box for "Full Control" for "Allow". Now all the boxes for Allow should be checked.
click OK.
Now you should have access to the drive.
Aug 12, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
509 people viewed this question
David Payne
David Payne
