Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Convergence my colors are screwed up
  • 2 more comments
  • carriesadie Jul 08, 2008
    red color seems to be out of line
  • Anonymous Jul 12, 2008
    double image and colors screwed up
  • Bcashier61 Nov 29, 2008
    I was hooking up a dvd player and somehow I got the coler off and I can seemto get it back
  • notso lucky Dec 18, 2008
    I dont have convergence on menu. How do I open fuse FL231?
Open fuse FL231 square brown cap next to flyback??? better or worst?
Posted on Oct 27, 2008
  • RCA Master
  • 5,138 Answers
Go into menu look on setup see if convergence comes up then do auto converg. if you do not see convergence on menu then you have an open fuse FL231 square brown cap next to flyback.
Posted on Sep 16, 2008
I bought this model from a friend and he mentioned that when moving the tv around it might get bumped a little bit and this could "throw the colors off". HE said i could pop the outter casing off...
Tv now have colors R,G,B lines mis alignments,have colors shadows or 3D pictures look alike?Yes,this tv have a problems known as a convergence problems,sorry but ur friend screw u over.This tv the convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.Fix the convergence board to solved the tv convergence picture problems.U have all the tools and can u do basic soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Color out of line i looks 3d in a fake way
the convergence ic of your tv is place at the main board.It is a two big ic that is soldered to the PCB with heat sink. To replace it you need to use a soldering iron ,soldering pump and a screw diver..unsolder it to the PCB replace it with a new one.Apply a silicon compound at the back of the IC before screwing it to the heat sink.
good luck hope this helps..
please rate my help
Jun 05, 2010 | Televison & Video
I just auto convergence my zenith tv and it fixed but still 3-D
Ur tv convergence ICS are dead.That why ur colors lines green,red,and blue are not linning up,and the colors look like 3-D pic.Must have soldering tools,and know soldering to fix convergence problems.Must replaced 2 STK convergence ICS and some or all of it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 29, 2010 | Zenith R56W36 56" Rear Projection...
Covergence problems or alingment , its has three colors without alingment please help me!!!
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
Color overlapping and curved picture. I have had problems in past with the green curved lines but fixed by adj the voltage screw
Ur convergence is dead,need a convergence kit,use what in that kit.U know how to solder right?Buy a convergence kit, with these websites.Tv Repair World.com,Ebay.com.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Adjust color, need service manual
On controlls the foucus...the other the brightness. I would not mess with them. 99% of the time the problems is one of the two listed below...
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 05, 2009 | Philips 9P5544C 55" Rear Projection...
Colors dont line up and green is "dancing" all over screen
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Problem with convergence
you dont need new CRTs (tubes) you need either the convergence Board or the convergence power supply board depending on the symptoms. If its only one color that is out of alignment its most likely the convergence board. If all the colors are out of alignment you need the convergence power supply board. you can get whichever one you need at the following link as they have both of those circuit boards and have free shipping. Heres the link,
http://servicemanuals.vstore.ca/
Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
GREEN GHOST
If you want to adjust focus and screen there is a focus block some sets they can be found on the front behind the gril then behind a cut out held in place by screws if not check from the rear. But a ghost like you say sounds like a convergence problem
Mar 21, 2008 | Philips 9P6444C 64" Rear Projection...
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
