Question about Bose (321GS) System
Bose 321 321 will not turn on. My Bose wont turn on.  No power.  Was working fine. Can you help
  • 5 more comments
  • JeaniePy Jul 22, 2008
    My Bose was playing fine and the next I tried to turn it on there was no power, no nothing.
  • TAKEITGREEZY Aug 21, 2008
    BOSE SYSTEM TURNED ON AND A WHILE LATTER JUST CUT OFF AND WONT POWER BACK ON.
  • Sheryle Nov 02, 2008
    Same thing, unplugged it to move it and when I plugged it back in, nothing, no display, no power
  • barltropa Nov 09, 2008
    I have set up my bose 321 as per instructions but nothing happens nothing comes on.
  • Fenster1 Apr 05, 2009
    Was working fine. Next time we tried to turn it on... nothing.
  • mikep366 Apr 14, 2009
    the bose 321 will not turn on
  • jefhow3099 Apr 18, 2009
    I unplug my system and plug it back in. The Bose 321 display comes on for a moment and then goes off. System will not power up.
Same problem
Posted on Oct 30, 2008
Got the same problem
Posted on Jul 07, 2008
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
BOSE 321
HI,
Go for a rest first by unplging it for 30min and then plug it back see if this helps or call tech support to oder an update disk.
Goodluck,
Please don't forget to rate the solution
May 01, 2008 | Bose (321GS) System
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
My Bose 321 system wont play CDs but it plays DVDs
lasers need changing expensive £200 or more
Dec 17, 2008 | Bose (321GS) System
BOSE 321
Have u tryed other disc ? if so your Bose system my have read a corrupted disc u may want to change out your IDE cable and if that doesn't work then corrupted files has made its way to one of your main broads.
Apr 20, 2008 | Bose (321GS) System
Bose 321
Same problem..it was working fine, shut off to untangle cords & it would not turn on
Nov 20, 2007 | Bose 3 2 1 GSX System
Bose (321GS) System Logo
683 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
