Question about Sub-Zero Refrigerators
Sub zero fridge
The ice maker has stopped producing ice.  I emptied the tray completely of old ice....a compulsion one a month....and for two days there's been no new ice. freezer seems to be freezing just fine.  Help?
  • gooey2 Jul 25, 2008
    sounds probable.  thank you.  any suggestion how to change that myself or is it a service call?
    again, thank you.
  • 330 Answers
Water filter maybe too dirty
Posted on Jul 05, 2008
  • Frank Chen Jul 25, 2008
    How handy you are? If you can find the water filter, release both side screws and put a new filter on and tighted it and check it, see if it is leaking, if it is not leaking, that's ok.
    But if it is leaking, and it is a copper hose to connected both sides of the filter, you have to use pipe cutter re-cut the copper hose and put a new fitting on the copper hose then tighted it. you have to know how.
    If this is your first time to change the filter, I hope you try it, if you don't try, you never know.
My ice machine stopped working on my fridge it's only 1 and 4 months old.any suggestions
If a year old there is no warranty for the ice maker or the dual water control valve. Feel around the ice slots to see if there is still sitting there? What is the model number of your fridge? If the ice tray slots are empty fill with tap water until near full and if the water freezes and the ice maker drops the ice into the ice container the problem will link to a water control valve problem. If there is ice in the slots and ice maker is on and does nothing then the problem is the ice maker and it will need to be replaced.
Nov 23, 2015 | Refrigerators
I have a 12 year old Sub Zero model 624. The ice maker has completely stopped producing ice. And actually, when opening things up we can see ice cubes have formed but they just haven't dumped into the...
This is the procedure but yours seems to be a faulty Icemaker and needs to be replaced since your freezer is cold enough to make ice rapidly.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Jul 27, 2011 | Sub-Zero 642
Ice maker not working in sub zero 561 model
you need to make sure that the unit has the water supply turned on. if you have a water dispensor on the front door and you are getting water then the water supply is on.
This ice maker is located in tight spot and has to be removed to cycle it manualy. so im going to give you a different way of doing a test.
first i want you to try to put your finger in the ice maker to see if you have any water or ice in it.
If it is empty then follow this step : try to get water in it without removing the ice maker. Do not fill it to the rim, just about halfway. This wont be easy, but if you do that you can check it the next day and see if it droped ice. if it did then your water valve is bad.
If it has ice in it then the ice maker in mostlikey bad.
or the switch for on and off is bad. (not common)
The freezer has to be under 14 F for most ice makers to operate.
Jan 07, 2010 | Sub-Zero 561 / F
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
No water for my sub zero ice maker system 532
Check in two places either behind the fridge or under the cabnit where the water supply is. If not there then check up underneath th back of the fridge
Feb 14, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Oct 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
227 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
