Wlan my laptop see,s our router but wont let me on internet the wlan says disconnected dont know what to do help i'm going mad
  • Tim Babcock
    Tim Babcock May 11, 2010
    is you wireless network card turned on and can scan for networks?
How about switching the cables around in different orders into the router that helped me
Posted on Jul 06, 2008
I have two laptops one wont connect to the internet explorer web
Very vague problem description.
Check the WGR614 settings, you may have activated the MAC address filter for wireless that allows only devices with known addresses to connect to the router.
Next is DHCP settings, is your router set up to provide IP addresses to devices (recommended) or is it set to static IPs? Your laptop must match this in its own network settings.
What about WLAN security? Is your laptop able to match the security settings of the router? Some older wireless devices do not support advanced encryption (TKIP, AES, ...) or any protocols beyond WEP.
Also very common: is the WLAN radio activated on your laptop? Sometimes success is just a gentle push away on an innocent looking switch at the laptop's edge.
Feb 07, 2010 | NetGear WGR614 Router
My wlan has disconnected
  • try to unplugged the cable to the computer and from the router/modem, or switch the ends, and plugged it back.
  • power cycle the modem and or the router
  • bypass the router
  • call your local internet service provider for any outage or problem on their end or to your local connection
May 05, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wlan is disconnected in acer laptop, what I can do to connect
because at a time both wirless and lan wont work so any one should be connected other wise whether u turned off the wirless lan button
Feb 26, 2009 | Computers & Internet
I cannot browse the internet. i am connected
Use this Tip as check list for your connection.
  1. connect your PC to router using a LAN cable and be sure you can browse
  2. connect to you router config page as admin and disable your security on Wlan, create a Unique SSID name for your WLAN.
  3. stay connected with Lan Cable and check if you see the just created WLAN (= unique SSID)
  4. Connect to Wlan using same parameters (no security)
  5. as soon you are sure connection established (browse Net) disconnect LAN cable to check reliability.
  6. reconnect Lan cable and reinstall security protection: WPA + PSK, TKIP passphrase, NO broadcast. and match router settings with PC settings.
  7. retry every step if not successfull until ypu master the environment.
Of course let us know the result by scoring this solution and feel free to ask for further help: leave your email if you need remote assistance to your PC.
Feb 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Hi, Hope this will help u..
1>connect LAN and check the WLAN light on wireless router It should be ON and solid, If not the you might need to reset the router
2>On your laptop click on start go to run (in case of XP) or go to start then search box (in case of vista)
3>type services.msc
4>For Xp check the wireless zero configuration service should be automatic and running
5>For vista WLAN service should be automatic and running
6>then go to start > run ( FOr XP) or start >
>search box(in case for vista)
7>type ncpa.cpl >click on OK
8>right click on wireless network icon and click on view available wireless networks.
9> Choose your network and click connect,
10> If it asks for WEP key , It might be written in your router.
If this doesn't work, you can contact your Internet service provider.
Dec 27, 2008 | Computers & Internet
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Can't find AOSS Button in psp
you are doing it in the wrong menu. you are setting up a connection to location free player
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly. first you need to have a wireless internet at home. next you need to turn on the wlan on your psp, located at the left side corner of your psp. search for a wlan around you. if its not secured, your lucky, you can connect anytime, but if it has a wep key, you need to find out the key to be able to connect. Switch the wlan button (located on the left side) to on and if don't aoss router seperate from the psp you cannot use automatic. So goto new connection and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
WLAN connection
make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Oct 04, 2007 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
