Alps MD 1000 Thermal Printer Logo
Posted on Dec 26, 2010
Approx .5 mm missout line every 9mm when doing any solid colour
foursaleoncr
Level 1:
New Friend:
  • Contributor 83 Answers
  • Posted on Dec 26, 2010
foursaleoncr
Contributor
Level 1:
New Friend:
Answers
83
Questions
0
Helped
21197
Points
95
Try cleaning the printhead as described in the user guide. Sometimes dirt can cause the line. If that does not work, you might have a bad element on the print head with is bad and cannot be repaired.
Ideal 4105 Cross Cut Machine made in Germany.
Question edited to fix jumbled order and add CAPS..
You posted to the Category 'Television and Video'. This an Office Shredder.
'Cross Cut' is what it is, bits too small to put back together. This machine has variable cuts and is designated 'P1, P2'.
Shredders IDEAL 4105
used machine
Specifications
Cutting width: 12mm, 9mm, 6mm, 3mm
Year of construction: 1988-1989
Productivity: approx. 70 sheets (DIN A4, 70g/m²)
Price: on request
Cutting speed: approx. 200 mm/s
the security level: P1 - P2
Power supply: 380 V/2.2 kW
https://www.google.com/search?q=ideal+4105+shredder
I'm trying to find out the bolt size for the head gasket screws
It is a Toyota tool for this vehicle.
Contact Toyota for advice.
2answers
What tool do I use to take off the break calipers to change brakes
9mm six point socket should be available from any good parts store or hardware.
2answers
What hex socket to remove brakes 2006 ford expedition front brakes
This is normally a 7mm hex key! Not usually supplied in a hex key set......any good auto parts store will have one!
1helpful
Dw738/739
The bearings should be 0.5mm . They should definitely not be touching the teeth, just behind the teeth is where they should be.
Feb 15, 2013 • Saws
Horizontal lines. Xerox 6505DN
clean the print heads and align them
1helpful
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Repeated horizontal lines Lines with cyan cartridge
In the Maintenance Menu, press Nozzle Check, do Head Cleaning and press Head Alignment and follow the instructions.
Can i use any usb cord to plug my printer into tower? Moved and found power cord but not other and i forgot what it looks like.
There are various types of USB cables for various purposes.
You need to look at the USB connector on the printer and the computer.
The USB connector on the computer will be a female connector approx 13mm x 5mm and have 4 contacts on one side.
The printer USB connector most likely will be a female connector approx 9mm x 7 mm and two corners have a small chamfer.
The printer cable will most likely be 4 pin USB A male to B male type.
Top Alps Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
ADMIN Andrew
ADMIN Andrew
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
