Question about Microwave Ovens
Microwave bulb I have a swan microwave model number SM 2060 and is it possible for me to change the bulb myself
  • Pete R Jul 05, 2008
    Same problem for a SA987CX model - the manual is no help
  • Microwave Ovens Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
How do you change the light bulb
If you post a model number someone may be able to help you.
May 13, 2014 | Emerson Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Swan sm21010 manual
light bulb in oven has gone how do i change it.?
Oct 21, 2010 | Microwave Ovens
Daewoo KOR 1B4H microwave light bulb burnt out. Can I change this myself?
It probably is, but I cannot find your model number on the Daewoo website to look in the manual.
Please confirm and reply the model number .
Jan 28, 2009 | Daewoo KOR-1B4H Microwave Oven
Manual for swan microwave sm 1080 to download?
Your best bet is to contact the dealer form whom you purchased it.
You may need to speak to the manager, but they should have contact information for all their manufacturers.
Please let us know what you find out so others can benefit.
Dec 22, 2008 | Microwave Ovens
Reset my clock
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you should call the dealer or store where you got the oven to see if they have a contact number for Swan.
Jan 21, 2008 | Microwave Ovens
Microwave Ovens Logo
155 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
