Question about Car Audio & Video
Hi, this arternoon i was sat in my mg zs180 with it in gear when all of a suden the car tryed 2 pull away and the clutch was stuck down, i turnd the car off and pulled it back up witch worked for a while then gets stuck agian, now its not doing anything but goes up and down as if there wasnt anythin there. i have ckecked the fluid but full help!! lol thanks
  • Anonymous May 22, 2009
    i have an mg zs 180 and the clutch pedal keeps getting stuck down please help
    Problem Solver:
  • 15 Answers
Hi, Go over to http://www.xpowerforums.com, and do a search for sheddist clutch, its basically an upgrade, as the clutch master, and slave cylinder are known to just go pop. The sheddist kit is an aftermarket kit which is 10x better and does away with low pedal etc. Its probably cheaper than buying the OEM tat aswell.
Posted on Jun 02, 2009
    Sergeant:
    Champion:
  • 330 Answers
Gear box had problem
Posted on Jul 05, 2008
I have a 1970 MG Midget I replaced the fuel pump and it runs good but won't go into gear. The clutch is very soft. It sat for about 11 months the slave cylinder was low on fluid Suggestions?
It sounds like you have air in the hydraulic clutch, this means that one of the cylinder is defective, it is best to replace both.
Aug 22, 2017 | MG Cars & Trucks
1994 Polaris 300 4x4 want shift into high range just grinds
Bad linkage between shift lever and the transmission.
Apr 07, 2015 | ATVs
Yamaha V Star 1300 starts but immediately shuts down went put into gear with clutch in
clutch plates stuck keep motor off put in high gear like 4th and push back and forth till plates unstick make sure kick stand is up
Jul 19, 2014 | 2007 Yamaha V Star 1300
2005 Subaru Forester brakes feel stuck "on"
They may be if it sat too long you could have corrosion build up which will go away, Check your E brake and cable, it may need adjustments or was not replaced correctly during the clutch job
Jul 02, 2013 | 2005 Chrysler 300
89 virago 250 clutch sticking
you could try riding the bike in third or fourth gear with the clutch lever pulled in and accelerate
Feb 08, 2013 | 2005 Yamaha Xv 250 Virago S
I have a 2002 honda vt600c bought it from a guy that I watched ride it but after it sat over winter the clutch doesnt seem to work ..shift into 1st and it kills bike. any ajustments I can make or do
Sounds like the clutch plates may be stuck together. Happened to me after a long trip in the rain and bike sat for a few weeks after that. Had to take the cluch discs out and clean them
Mar 25, 2012 | 2004 Honda VT 600 C Shadow
My car is a 94 325i manual. it goes into gears much better when it's off but when it's on it will not shift into gears and if i force it i hear a horrible grinding noise.
you have 2 choices either the clutch is not disengageing properly or the gearbox is shot.put the car in first,put the clutch pedal down, then start the car and if its trying to pull away before you take you foot of the clutch you have you answer....if its the clutch cable you can adjust it..
Aug 26, 2010 | 1994 BMW 3 Series
Clutch
Hi, you might find the nut holding the clutch basket onto the shaft has come loose, so instead of pulling the clutch plates apart you are just pulling the clutch basket along the shaft.
or if the bike has sat for a while you might find the clutch plates have stuck together, this isn't that rare, you can start the bike and roll it along at about 1st gear speed, then click it into gear, then pull the clutch in and rev the engine, this should make the plates loose again. hope this helps, please rate, thanks, good luck
Jul 23, 2010 | 2004 Suzuki RM 125
Clutch sudenly not working .clutch lever tight when pulled in. but clutch not engauging
Is it not engaging, or not disengaging? Does it just slip when you put it in gear and let out on the clutch? You can try a clutch adjustment, but may need to look at the clutch discs themselves.
Mar 05, 2009 | 2000 Yamaha DT 125 R
Gearbox spinning,with clutch depressed,gearbox crunching.
needs a new clutch ,pressure plate dragging caused by worn springs
Dec 30, 2008 | 2005 Renault 181
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
