Question about Roper RS22AQXKQ Side by Side Refrigerator
RS22AWXBW01 freezer Coils have frozen over in freezer, Ice maker not functioning, no cooling in refer side. Could Thermostat, timer, or defrost coil be problem?
    Sergeant:
    Champion:
  • 330 Answers
Defrost coil maybe has problem
Posted on Jul 05, 2008
Freezer of my Jenn-Air side-by-side refrigerator is not keeping items, especially ice cream, frozen. The ice maker has also stopped making ice.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this will help in solving the problem, do take care......
Jun 09, 2011 | Refrigerators
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
We have A GE HSS25GFPAWW side by side and the freezer doesn't defrost so the fresh food side gets warm. We pulled the panel off and the coils are frozen, the fan works. Could it be the heater coil or the...
Yes very much possible that temperature sensor( defrost thermostat) or heater coils ( defrost heater) is faulty.. If you see, too much ice frost collected there, then its defrost related issue. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
Ge profile PSS26MGP side by side installed in Oct 2008. Background: on 1-03-2011 freeze-refer temps approx 13 and 48, apples in top deli-fresh drawer were frozen. Ice maker not making ice, minimal water...
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a Side x Side style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing,or an inefficient not 100% pumping compressor.
Feb 07, 2011 | Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a top freezer/refrigerator and notice that ice is accumulating in the freezer and underneath the freezer in the fridge. What are my settings supposed to be set at? What should I do?
It sounds as if your refrigerator has stopped automatic defrosting of the evaporator coil or has a plugged defrost drain.. Below is some information provided by: www.repairclinic.com, to help you understand what may be wrong with your unit. If it is not cooling properly, you may be able to get it cooling again, temporarily by removing all perishable items, unplugging the unit, and allowing it to stand idle wth the doors open. This will allow the ice to melt, which will allow air flow to resume normally through the unit. Allow several hours for the ice to thaw completely, then close the doors and return it to an operational status. Put water in both compartments and when satisfied with the results of temperature, i.e. frozen in freezer and cold in fresh food compartment, you can put perishables back in. This will allow normal operation for only about a week until the defective part gets replaced, then it will start warming up again.
If the drain is plugged then the diagrams should show the routing so you can clean it out.
Today, all but the smaller, apartment-sized refrigerators are self-defrosting. Self-defrosting means what it implies--though frost continues to accumulate inside the refrigerator, it melts automatically. The self-defrosting system has three functional components:
Defrost timer
Defrost heater
Defrost thermostat.
Defrost timer The timer is like a clock. It continually advances, 24 hours a day. Every 6 to 8 hours, the timer turns off the cooling system of the refrigerator and turns on the defrost heater.
Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts.
As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator.
Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
Detailed parts diagram:
http://www.repairclinic.com/Refrigerator-Freezer-On-Top-Appliance-Diagram
Aug 13, 2009 | Whirlpool Refrigerators
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Roper RS22AQXKQ Side by Side Refrigerator Logo
    71 people viewed this question
    Top Roper Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    John Tripp
    John Tripp
    Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
