Question about Samsung ML 2010 Laser Printer
Samsung ML 2010
I have a paper jam. How to I fix it?
  • 1 more comment
  • cinniscec Jul 10, 2008
    2 sheets of paper jammed in rollers
  • Gayle Marie Jul 17, 2008
    Paper is jammed in the red roller at the top (where it is hot!). It continually cramps the paper into a fan and I have to pull it out when cooled down but now a piece of paper is stuck! I can't seem to find any openings to get at that particular space. Help!
  • rodionx Aug 03, 2008
    Exactly the same problem as described previously. The paper prints fine, but when it is leaving the machine it jams in front of the red roller which then crimps it into a fan. I'm using standard printer paper that I've always used successfully with this machine.
I just need this driver files in windows xp s/w
Posted on Jul 15, 2008
My Samsung ML-2010 laser printer grabbed up 2 sheets of paper and now both are jammed. I can't pull them out. Now what could I do?
Removing paper jams from printers can be tricky. You'll want to be careful to not tear off the paper. Always try to pull the paper in the feed direction if you can. The Samsung should have a doo in the back or in the paper area that can be opened to assist in removing the jam. If this persists, you may need to replace the paper feed rollers.
Feb 03, 2011 | Samsung Monitors&Printers Monochrome Laser...
ML 2010 Laser Printer: I HAVE A SAMSUNG 4200 IT IS SHOWING PAPER JAM, BUT...
you may want to check again on the printer.if it show paper jam.
open up the fron door and bnack door. remove the toner and check if there is any small pices of paper still jam in the printer.
if not try and see if the fuser flag is not sitting properly. you might need to do small adjustment.
May 18, 2010 | Samsung ML 2010 Laser Printer
Printer jammed - removed jam but paper guide not resetting and on line error remains.
Had the same problem. Make sure you have put enough paper in paper feed tray (more than 10 sheets) and lock paper from sides. Take out ink cartridge and reinsert it.
Hope this works for you ^_^
Jul 17, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 printer; paper jam
Lise, That is VERY similar to what I experienced yesterday. You can probably fix this by cleaning the rollers (all of them) thoroughly. See what I did exactly, and find directions to all the rollers from your manufacturer: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if that helped you as it helped me solve the problem completely.
Apr 01, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Problem
paper registration system damaged.  Check all sensors in this system.
Oct 17, 2008 | Samsung ML 2010 Laser Printer
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
117 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
