Hi there are lots of sources for the part. You just need to pick one that is convenient for you. click here
however, the blinking of the power indicator, is reflecting a fault in the set. Try powering it down for 30 mins by unplugging at the wall to do a reset, then power up again and see if the fault continues.
If you have no luck, I suggest a repair man is in order. repairs can get complicated to TV, and it is always cheaper to professional fix the original fault, not try to work out what has happened from other attempts at repair.
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
Maybe the push button switch is defected ,the solder of the switch is
brittle , or crack or cold,try to resolder the switch, if not change it
with new one.I incounter like this problem before in the switch , i
only resolder the joint then its ok,,try this also maybe can help...
Magnovox Model # 55P8288 46" screen
On / Off buttom blinks but doesn't turn on. My 11 year old played with it over and over by pushing the Source Select button after I had given up. The TV turned on and was working for months until I pushed the Source Select button again to try to get a DVD player to work.I think that button may be defective. I have tried soldering it but I need to know if I am soldering at the right point.If I push the Source select button or the channel button the blinking light on the on/off switch will stop for a couple of seconds and then resume blinking.I wrote down the P{hillips part number which is 313501707611, do you know where I can get this part?
