Question about Dell Inspiron 6000 Notebook
Power issue The laptop isn't charging and the adapter is plugged in. I had a new adapter sent and that wasnt the issue. It has something to do with the adapter in the laptop not be attached to the motherboard still. Please help jake_divjak@yahoo.com Yes. I have smae problem.
    Problem Solver:
  • 5 Answers
Hello, If you are still in need of getting this fixed I can help. I have replaced many of these DC jacks and have since moved my service to ebay. If interested you can look at the ebay link that I have provided below. This will take you directly to my service ad. As you will see, I am a certified computer technician and on top of that, I have a 100% positive feedback rating. My price is very reasonable as well. So if you would like to get your system fixed, please consider me. The link is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=220284642915&ssPageName=STRK:MESE:IT&ih=012 Thank you and I look forward to hearing from you! Sam
Posted on Sep 27, 2008
  • 47 Answers
Does your laptop go on just plugged in? If not it could be the power jack has broken inside. Cheap part, but VERY expensive to repair unless you do it yourself. A repair shop will charge around 300.00 or more for the repair.
Read this, and it will give a example of how to do it.
http://www.instructables.com/id/Replace-broken-DC-power-jack-on-your-laptop-comput/
Posted on Jul 06, 2008
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
My laptop charger stopped working so i bought a new one last week and i plugged it into the wall then into my laptop i went to turn it on and i noticed the the light that lets me know that its charging...
If you replaced the AC adapter, then the issue is the Power board on the system Depending one the model, it may be part of the motherboard or a seperate part
Jun 12, 2011 | Computers & Internet
COMPAQ V2000 BATTERY NOT CHARGING
Try to isolate the problem first. See whether it's a laptop issue or an adapter issue. If the adapter has a light, see if the light is coming on when you connect it. Also see if the laptop works if you remove the batteries and connect the adapter.
There could be several issues here:
1. Your adapter's light may be coming on, but it still might not be delivering power to the pin. If you have a multimeter, connect it to the terminals of the charger and see if you get a voltage reading; if not, there may be a problem with the cable running from the adapter to the laptop or the adapter itself may not be giving the right voltage.
2. The second possibility is that the adapter is OK, but the laptop's power connector is faulty. This will require a technician to remove the old connector and solder a new one into place.
3. If both the adapter and the connector are fine, then the problem is most likely with your charging circuit, which is inside the laptop. This circuit powers the laptop through the batteries, and will once again have to be inspected by a qualified technician.
Hope this helps
May 24, 2011 | HP Compaq Presario V2000 Notebook
I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
May 13, 2011 | Samsung Computers & Internet
Laptop will not power up. Hp sent a new wall adapter but will not power up....pulled battery and plugged in and still nothing.
By what you have posted it seems as if your computer won't power on at all even when the cord is plugged in. You also tried it with a new power cord. If that didn't solve the issue then your motherboard has gone bad. I'm guessing your computer is still under warranty since they sent you a new AC adapter. Tell them that the motherboard needs to be replaced and send it out to them.
Jul 17, 2010 | HP SMART BUY 8530P 253G 2GB 320GB DVDRW...
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the...
i had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Jun 16, 2009 | Dell Inspiron 1525 Laptop
Power plug socket on notebook has failed.
You will have to have a new d/c jack installed on the motherboard. Not a big job, but you might want to have a techie friend do it for you, as it will require some soldering.
Mar 18, 2009 | Computers & Internet
Doesnt charge
This could most probably be a battery issue. To check if it is really a battery issue, remove the battery and plug in the AC adapter. If the computer powers up, then this is definitely a battery issue and you'll need to purchase a new battery or call your computer's manufacturer and ask them if they have battery exchange programs.
Sep 17, 2008 | Acer Aspire 3050-1733 Notebook
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
95 people viewed this question
Alun Cox
