Back to:
Tags:
Harley Davidson Harley-Davidson Motorcycle Fat-Boy Desktop Telephone
Can't figure it out !!!!
posted by lolaglow67 on Jul 05, 2008
1981 Lowrider cut out on road getting gas, spark but wont start
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 06, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2405 votes
There are 2 major requirement for a gasoline engine to fire, fuel and ignition. Since you have spark, then ignition is the least likely problem. No fuel could be verified by removing the air cleaner and pouring a small amount of fuel down the throat, start the bike, if it start and runs (even for just a moment), you have verified the fuel problem.
Problems then could be traced along the fuel flow from the ank all the way to the carburator. In some instances of run out of fuel, the bike will have a hard time starting due to:
1. air bubbles in the fuel lines;
2. valve in carb stuck in close position;
3. flooding of both carb and intakes;
4. (in some cases) vacuum insifficient to open petcock or fuel valve/switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on can't figure it out !!!!:
I don't want to Accept this solution
Can you Help with these Phones problems?
Harley Davidson Harley-Davidson Motorcycle...
On 2003 Road Glide when I switch from low beam to high...
I started to leave work yesterday.It turned over like it...
After rebuilding the transmission, 1500 miles later, 4th...
there is a grinding noise coming from behind my point...
grinding noise in side points cover
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
