Question about Kenwood Car Audio & Video
Need unlock code for kdc-mp825 - Kenwood Car Audio & Video
  • tgormont Jul 06, 2008
    thanks pyropcman it worked now i have to find the user manual. you rule
  • 405 Answers
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222"
Posted on Jul 05, 2008
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
I need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Mar 27, 2010 | Kenwood KDC-MP2035 CD Player
Demo mode on and system does not stay on
Try to put a cd in,this should kill the demo mode.
May 13, 2009 | Kenwood Sirius KDC-MP825 CD Player
Unlock code
This is the only way to clear the code. You must have the remote to do this, it will not work without the remote. I work at an authorized Kenwood service center and tell you for certain that this is the only way it can be done. If you do not have a remote, you will either need to buy one or borrow one from somebody else who has a Kenwood radio. Most all Kenwood car stereo remotes will work, it does not need to be from the same model number but it must be a Kenwood car stereo remote. If you can not find a remote for this then you will need to take the radio to an authorized Kenwood service center and they will usually do it for a small fee.
The first step is the only part of this procedure that you do not use the remote.
1. During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2. Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the Track
Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the Track
Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the Track
Up key. (Enters an “R” )
3. Security function is canceled and unit sets to All-Off mode.
4. Code request mode appears if a mistake was made in entering
the numbers.
Dec 09, 2008 | Kenwood KDC-MP228 CD Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-MP825 car stereo problem
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
Aug 20, 2007 | Kenwood KDC-MPV8025 CD Player
Door Opens then closes and Powers Off
Try holding down BUTTON [5], then press the RESET button (you'll need a ballpen between the AUTO and SCRL buttons). This worked on the KDC-MP825 (very similar to the MPV8025) when my wife had the same problem this month.
May 21, 2007 | Kenwood KDC-MPV8025 CD Player
Car Audio & Video Logo
195 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
