Question about Samsung PCJ534RF 53" Rear Projection Television
Color not sharp
I just bought a used 53" Samsung on a stand, flat screen and the color is really dull.  I have tried several times to adjust.  The color is just dull.  It only has a red and green tint and the red seems to domintate.  Any help?  Can it be fixed?  Thank you.
  • myronabeyta Jul 05, 2008
    Might the convergence have anything to do with it?
    It seems the consensus that I need to find a technician to solve the problems. Was thinking that was needed but hoping it was not. Thank all of you for your advice. I really appreciate it.
  • 691 Answers
This sounds like you have a convergence problem with TV. This is not something you can rectify yourself easily. You need to know the convergence procedure to set it correctly. You need to call a service technician who can complete this procedure for you. He/she can also flash focus for you.
Posted on Jul 05, 2008
    Master:
  • 848 Answers
Check this
Bad connections or bad component in video amplifier or on CRT neck board for that color.
Fault in chroma decoder.
Weak gun in CRT (reduced color).
  • gopinath pasupathy Jul 05, 2008
    It is probably not the CRT. Do you have a scope? Check for the R, G, and B video signals at the CRT. You will probably find no signals for the defective colors.
    This is almost certainly a chroma circuit problem as any failure of the CRT or a video driver would cause it to lose a single color - the other two would be ok. Therefore, it is probably NOT the CRT or a driver on the little board on the neck of the CRT.
    Try turning up the SCREEN control to see if you can get a G and B raster just to confirm that the CRT is ok.
    Locate the video drive from the mainboard for the good and a bad color. Interchange them and see if the problem moves. If so, then there is a video signal problem. If not, it is on the little CRT board.
    It could be a defective chroma IC or something else in the chroma decoder.
    Genius:
  • 1,665 Answers
Display Panel faults:
Vertical (source) faults are usually within the actual panel (Lines/Bands down Picture)
Horizontal (gate) faults are unually within the actual panel (Bands/Lines across the screen)
Better take it to a service station to check it.
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 53 uwx10ba color will not stay balanced. mostly drifts into the red. Pulled off the front and adjust the drivers to correct but will go back to a redish shift. Any ideas??
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Green and purple band of color
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Double picture & color problem
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Poor picture quality on Hitachi model # 53fdx01b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 20, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Picture Problems: Snow, color, lines
*Screen Looks 3-D
*Colors wont align
Problem #2
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Hitachi Mo# 53uwx10ba double image
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Samsung PCJ534RF 53" Rear Projection Television Logo
66 people viewed this question
cce772000
Level 1 Expert
