Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Red on/off indicator light never turns off
The red power indicator light on my Hitachi 43FDX10B never turns off. I tried unplugging the set but it remains on.Please advise
  • gspitzner Sep 11, 2008
    My 43 Hitachi projection just started doing this yesterday. Same thing unplugged but no change.
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Posted on Jul 18, 2008
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
I have a Hitachi 43FDX10B that has got too much red in the picture..is it the bulb or something else?..the picture has soft edges and all the red and purple tones are overwhelming
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
My power light stays lit
Good Day, P1Winfrey;;
IT sounds like you need to call a Factory Authorized Service Center for HIT, to come out to your home and give a written estimate B4 repairs begin. Normal cost is about $550.00.
Good Luck, big IRISH. PS too many things on this TV can cause this....sorry.
Sep 01, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Power keeps surging and won't stay on
I will need the model number of your set in order to make any suggestions as to what possibly could be causeing the problem
May 17, 2008 | Hitachi Televison & Video
No turn on
try unpluging convergence yoke and try turning on the set if still try looking at green lights and let me know wichone stays on ..
Feb 25, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi rear projection 60" tv, power failure
Yes,it's worth it ! Check for bad C702 capacitor next to HV
transformer covered partially by glue and E994 open pico fuse
in power supply .part # for cap 1-161-754-00 102K / 3KV.......T.
Dec 04, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX10B rear projection tv
Do you have a cable box which turns on and off with the tv? If so is your cable box input on the video 4 mode? If that is the case look under the video menu for advanced selections, you will see a selection for auto/on/off for video 4, select off. Check manul under video and it will explain also.
Nov 30, 2007 | Hitachi 43FDX01B TV
Hitachi
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
63 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
