Question about Neff 24 in. S5409X0 Built-in Dishwasher
NEFF S6R28F Dishwasher
The dwasher does'nt seem to want to do anything when selection knob is turned to activate a programme. Power is available and the machine sounds as if it tries to go into a washing cycle but after 30secs or so, the machine stops "whirring" and does nothing. This is after the machine had worked for 1 wash fine after having moved into the house. Could it have been that the earlier owner had not used it much and although it worked initially, it now requires "priming" (found this description of what could be wrong from an earlier similar solution to this problem when machine has left idle for some time)?
  • 883 Answers
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
  • 159 Answers
SOURCE: Machine won't activate
well I never heard of that brand so because you said a new flat Im guessing your form England. Good luck with the move. Ok I belive your problem is possibly the main control bord is bad.what you describe sounds like it. the only way to rest it it would be to replace the bord. doing that it should function normally. Good luck.
Posted on Aug 22, 2007
  • 641 Answers
SOURCE: Neff Dishwasher
It sound like a detergent cup issue (not opened in time). The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Let me know with your results. Good luck!
Posted on Sep 06, 2007
  • 338 Answers
SOURCE: Neff s5946 slimline built in dishwasher. Fills
if you only hear the clunking sound while the dishwasher is filling then the inlet valve is bad.. i would replace it because if it fails completely you could possibly have a flood..
Posted on Feb 20, 2009
  • 10 Answers
SOURCE: Machine don't fill & Control knob don't advance automatically
Every machine is wired differently. It's possible but not likely that it has a fuse in the circuitry. My guess is that the level sensing tube is blocked and the washer thinks it is at the preset level, ior that the sensing tube has a leak in it. Similar to a hole in a straw. The washer can not advance and operate in automatic if its preset is not satisfied. The preset here is wherever you or it sets the level. Once thw washer fills then a contact closes and turns the timer motor on and advances the timer.
Posted on Mar 25, 2009
Selecting any programme , my Auto 3 in 1 dishwasher will only go onto a rinse cycle
reset it, switch off the mains & back on again, or you could have a problem with the tablet release. so it thinks its finished washing.
Oct 08, 2014 | Neff Dishwashers
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
How to fix neff dishwasher
Sounds like you have water in the base of the appliance caused by a leak, which in turn has activated the anti flooding device. OR the control module is faulty.
Remove appliance from housing and remove water from base, check for leaks.
OR
Replaced control module
Aug 23, 2014 | Neff 24 in. S5409X0 Built-in Dishwasher
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Nov 05, 2008 | Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher takes 3 hours, fails to dry dishes
mine has just started to do the same thing.... not sure why :o(
Aug 18, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff Dishwasher
Sep 05, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Neff 24 in. S5409X0 Built-in Dishwasher Logo
204 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
