Question about Sony KP-65XBR10W 65" Rear Projection Television
Trinitron XBR Projection - No Picture
I picked up a Trinitron XBR VideoScope Projection television which has no picture and not much except for a small click in the back of the unit happens when I go to turn it on. The red stand-by light flashes continuously, and there seems to be some interval between the flashes, but I have not counted them.
Any suggestions would be greatly appreciated
  • 1 more comment
  • DustinF534 Jul 06, 2008
    The model is a KP53XBR45.
    There is no INPUT or MENU button on the front of the TV. There IS the TV/Video button, but that's all, along with the Channel, Volume, and Power buttons.
    There does not seem to be any interval between the flashes. It does seem to flash 9 times, then pause for a split second, then continue flashing with no other intervals.
  • 43 Answers
Hi dustin,
 this is a common problem in all latest sony xbr projections tv....
9 flashes is the ZCD error. Zero crossing error detector.
9 blinks is a no code for that model,you could go into the service menu and see whats the # for you fault.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem na
dude, ur problem is due to defect in IK video path. if u have d technical knowledge u can replace d IC by ur own..if u don't, plz cal d near by technician or use our projection tv repairman to find the nearest repairman who ll surely sort out ur problem...
good luck
Posted on Jul 06, 2008
  • Senthilappan PC
    Senthilappan PC Jul 06, 2008
    9 blinks is a no code for that modle,you could go into the service menu and see whats the # for you fault.Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
  • Senthilappan PC
    If you press on the remote, display,5, vol down, power, the TV will power up in diagnostic mode. ie. 9 ZCD 180 was found on the one I am working on. (Error 9 ZCD was encountered 180 times.)
    I am waiting on the service bulletin but from what I have found on here, the first thing to try is to resolder several components.
    On the A-board, D611, D690 and I think Q605, Q690 and D647 (may be on C board?)
    so dustin, if u have technical knowledge resolder the components..if u don't know to solder, plz cal d near by technician, he ll solve ur problem..
    Guru:
  • 1,894 Answers
You must note down the interval between the flashes.
only that can help us to find or decode the problem
please let us know
    Genius:
  • 2,035 Answers
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Certainly, I can help you. I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck..............
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
HI I have a 1998 Sony Videoscope XBR 53 in. Projection TV. When you turn it on the sound is fine but sometimes the picture comes right on and sometimes it can take hours. Can anyone give me some advice....
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
regards
shaun
Oct 06, 2010 | Sony KP-53S65 53" Rear Projection...
Distorted curved picture upper and lower screen on my Sony Videoscope XBR model kp53xbr35
CONVERGENCE PROBLEMS ARE COMMON ON THIS MODEL. THIS WILL REQUIRE PARTS REPLACEMENT.
Dec 27, 2009 | Televison & Video
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony Trinitron XBR
VHF/UHF works for me. Make sure the game/tv/video rtc tab is correct
Dec 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
254 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
