Question about Rowenta DX6700 Iron
Rowenta Iron Problems
Hello!
My iron doesn't want to turn on when I want to iron. I think it has something to do with the automatic on and off mechanism. If I shake it or turn it upside down, it will start, but then I have to be real careful about positioning it right so that it doesn't go off. My husband is a real handy guy and probably could fix it, but he says that it takes a special kind of tool to take it apart. Any ideas? I would just as soon not spend the $$ on a new one if I can help it!
AM
    Scholar:
  • 70 Answers
Rowenta has an auto shutoff feature if the iron is not used for awhile. They use multi-point security Torx head screws that require the appropriate set of bits/driver kit that may be obtained at your local Kragen's or Harbor Freight tools to access the position/timer switch mechanism. Open it carefully so you can see if the switch is somehow mechanically mispositioned or sticking. You may also want to store the iron, cool and reservoir empty in the normal upright position.
Posted on Jul 26, 2008
My rowenta Dw9280 steam iron won,t heat up.
Failure of heating element, control, or both
Mar 14, 2018 | Rowenta Irons
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
I plug the iron in , 5 minutes later it turns off ! Is that a auto shut-off problem or something else
The iron has an auto shut off of usually 8 minutes. The iron will automatically turn on if you move the iron. If this does not answer your concern, let me know and we can look for a solution. Thanks.
Mar 15, 2011 | Rowenta Irons
My rowenta iron shuts off in the middle of ironing & spits water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 09, 2010 | Rowenta Powerglide DE011 Iron with Auto...
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta iron
Torx Screwdriver is needed
Jul 02, 2008 | Rowenta DX6700 Iron
Rowenta DX6700 Iron Logo
340 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
