-   I have the same problem even with new cartridge from Dell-   Guest
Nov 09, 2008
-   I have replaced the color cartridge twice and still get same message "Cartridge Missing"... I have cleaned the heads via the clean program that is part of the printer as well as cleaning the cartridge heads with alcohol and q-tips, but still this printer only prints in black and continues to display the same message..........help-   will164
Oct 17, 2008
-   None of the described remedies helps at all. -   Guest
Jul 19, 2008
-   My DELL AIO 942 was working fine, when suddenly started getting "cartridge error" message on screen, and now won't print at all. I've tried reinstalling cartridges and unplugging printer, hoping it would reset, but nothing changed.
-   56cruser
try reseating the cartridge & also reseat the power brick assembly.....also if u hv the factory installed cartridges....try installing those & chk if u still get the error...
When I print, I am fine; although when I use the copy function either in color or black; the left...
(More)
When I print, I am fine; although when I use the copy function either in color or black; the left margin is faded.
When I go to scan a document, I make sure it is in scan mode, hit start and nothing happens. Any...
(More)
When I go to scan a document, I make sure it is in scan mode, hit start and nothing happens. Any ideas?
