Question about Kenwood KDC-MP528 CD Player
NEED THE MANUAL
So what do you push after you hold the menu button down for 2 seconds?
I couldn't get the manual. Can you email it to me.
Don't know if links are allowed on the forum but if so you can download it from here:
http://inform3.kenwoodusa.com/manuals/KDCX589.pdf
This is a 40 page manual for three different models, so don't let the KDCX589 filename discourage you
Posted on Jul 07, 2008
RESET DRUM
TRY THIS
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%
Jul 22, 2014 | OKI C5650n LED Laser Printer
Hi, i have a 42PF5421, i have had foreign language on my menu for 2 years now, but im finally going mad. Ive tried going to the menu, but its just the hdmenu. I cant get to any install/language options. ...
On the right hand side of the TV (NOT the remote control), push the menu button (there are 4 buttons on the side of the TV, menu one is 2nd from the top) and hold it down for 10 seconds. The green light on the TV will flash continuously while you're holding it down. Then the language selection feature pops up. Default was English for me. Push the menu button again to select.
The manual (http://download.p4c.philips.com/files/4/42pf5421_10/42pf5421_10_dfu_eng.pdf) does not include this
May 02, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
How do you set the clock on the Kenwood DPX302
In the standby mode:
1. Push the Control knob towards up or down, select "CLK ADJ"
2. Press the Control knob for about 1 second, the clock display blinks
3. Push the Control knob towards up or down to set the hour
Push the Control knob towards right or left to adjust the minutes,
4. Press the Menu button
Mar 01, 2011 | Kenwood DPX302 CD Player
My cs8110 won come on
The standalone unit has the same programing as the salt water unit with the integrated pump. When you see "FP" it is in Filter Pump mode. Simply press the down button for 2 seconds, then the up button for 2 seconds to unlock the pad. Either change your run time or leave it the same and lock the pad (hold the down button for 2 seconds and then press the up button for 2 seconds). After it locks you should see the green working light come on. The reason FP isn't in the manual is that you don't need Filter pump mode on the stand alone unit (I think it should still be in there as it is still possible to get into this mode on accident).
Aug 25, 2010 | Intex Automatic Salt Water System for ...
Oki C6100 Laser Printer drum reset - from Fatal
8. Restart printer.
Feb 09, 2010 | OKI C6100n Laser Printer
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
R56w36 convergence adjustment
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
Mar 13, 2009 | Zenith R56W36 56" Rear Projection...
Cant get the unit out of Demo Mode
I had the same problem and I called 1-800-KENWOOD. There is a button to the left of your preset station buttons and it is the menu button. It is also the B.Boost button. When in standby mode, press this Menu button and hold it for a second or so and the menu will appear. The manual conveinently left this part out. Once you hold that button you can then move the control knob up or down till it comes to DEMO and then hold the control knob down for 2 seconds to change it from DEMO mode, like the manual tells you to. They always leave out the most important part. This MENU button will be your friend from now on, and it also goes to the option that will set the clock. The people at 1-800-KENWOOD were very helpful should you need more assistance. Good luck!
Dec 05, 2007 | Kenwood KDC-MP335 CD Player
How do i tune a bush ws6672 tv
press and hold menu for 2 sec then press again will put u into manual tune.
if u still hav problems email me and i send u manual vespa_man@hotmail.co.uk
Oct 15, 2007 | Bush WS6671 28" TV
Kenwood KDC-MP528 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
