Question about Toshiba Computers & Internet
My toshiba laptop does not come on. I have changed the fuse in the plug but still there is no power. Do I need to change the adapter.
    Scholar:
  • 174 Answers
Have you got a multimeter check first the adapter is give the proper charge output. i hope your laptop is working with battery
Posted on Jul 05, 2008
Toshiba laptop power on light bling after not on
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 28, 2013 | Toshiba Computers & Internet
Plugged in cord, and computer went black
Remove the main battery and power up, if no change! have the power supply tested, if okay! sub out the ram memory one at a time and test, if no! the DC jack in the laptop do cause issues, at this level I recommend a tecnnician to get to the bottom of this.
Apr 04, 2012 | Toshiba Satellite M645-S4061 Notebook
I have a Toshiba PSAF3U-0NR00V, every time i plug the charger to the laptop it goes off, but comes on without the charger, it would charge the laptop,when it's turned off but if i try turning it on...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 23, 2011 | Toshiba Satellite A205-S5804 Notebook
My computer goes blank every time my charger is plugged in
Hello.
Hope this helps.
May 28, 2011 | Toshiba Satellite L305-S5907 Laptop
Its my sister's toshiba a205-s4577 it does not boot up at all. when i plug in the ac power, the blue plug light goes on, but when i press the power button, all the lights flash for a second and then...
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you are knowledgeable, remove the heatsink and apply new thermal paste.
But, it certainly could be the mobo.
Hope this helps.
Jan 24, 2011 | Toshiba Satellite A205-S4617 Notebook
When plugged in the laptop stops. but with back up power, it is working
If you mean it doesn't work on battery, change the battery. (Cheapest is on ebay). If you mean it won't work on the Adapter alone, change the Adapter. (Cheapest on ebay).
Or please clarify.
Jan 06, 2011 | Toshiba Satellite Pro L300 Notebook
Hanging
power from adapter no capable to supply and need more wattage or change adapter with higher amperage. but still you need to change new battery.
Apr 02, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
NO POWER AT ALL on Toshiba Satellite A105-S2101. PLEASE HELP!
Try disconnecting the power outlet and removing the battery for about 10 seconds.
Hope this helps
Alex
www.CAS411.com
Jan 01, 2009 | Toshiba (K000002020) Motherboard
Toshiba not getting power
You may have completely drained your battery which it will need a full recharge before it will work again.
Oct 23, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
