Question about Danby DWC283BLS Wine Cooler
Danby wine chiller
Compressor won't turn off. Goes down to freezing. Is this somthing I can do, or do I need to call a service tech. Thanks
  • carneyf15 Jul 25, 2008
    I have the exact same problem - compressor won't shut off and lower section goes to 32 degrees despite having it set to 44 degrees. Seems like a thermostat problem.
I found the solution to my case. The continuous compressor running problem started a few days after we moved the unit from a hardwood floor to a room where it is on a carpet. For some reason, this caused some sort of freeze up. I solved the issue by raising the unit about 1/2" using a couple of boards I had and placing them under the legs. Now I need to figure out a bit more visually pleasing solution, but raising it up cured my freezing problem.
Posted on Aug 24, 2008
  • carneyf15 Oct 24, 2008
    My apologies - I have to amend my previous post.  The freezing problem came back despite raising the unit off the floor.
    The REAL fix was to order a new thermostat from Danby and replace it.  It wasn't too difficult to do - the thermostat is a small circuit board that is in the separator between the upper and lower sections, right behind the temperature indicators.  To get to it, you need to remove the top two shelves (one screw on each side holding a clip to keep the shelf in place), and two screws on top of the separator panel.  The thermostat is held in place by four clips that you can squeeze closed with needle nosed-pliers, then pull up on the circuit board.  You need to swap about 10 connectors for the various temperature sensors, fans, temperature indicators, etc., and push the card back into place on the four clips.  Finally, replace the top separator panel and shelf clips and you are done.
    I got the part from Danby customer service (1-800-263-2629) - the lady called it the thermostat, but the invoice shows it as a "DWC 282 Control Panel," part number JG32DQ-05, for about $35 including shipping.  Sears Parts Direct.com also carries the part, but it's a bit more expensive and currently on back order.  The website does have a parts diagram, but the part they indicate is the "Controller" doesn't really look like the actual part.
    Hope this helps!
Danby Compressor Runs
Can you please describe your problem.
May 05, 2008 | Danby DWC283BLS Wine Cooler
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
I need to replace the broken glass door on my wine cooler. Where can I get one ordered?
look around for your model of wine chiller and may be somthing will pop up
Jun 22, 2014 | Soleus JC-128 Wine Cooler
Unit does not get cool. I can hear the compressor kick on, but it goes off about 15 seconds later. After a minute or so it goes on again only to shut off again
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Aug 21, 2009 | Danby DWC283BLS Wine Cooler
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps!
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Not staying cold all of a sudden
THE PROBLEM NEEDS THE ASSISTANCE OF A TECH THER MIGHT BE A PROBLEM WITH THE GAS CHARGE OR THE COMPRESSOR NOT PUMPNG EFFICANTLY.GOODLUCK. MOHAMED
Jun 22, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
1,025 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
