Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Beater bar belt
I need help installing the beater bar belt
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=744864
Posted by rubyspider on Jul 05, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. All you need to do id to remove the bottom plate by removing either the screws, clips or levers and the bottom plate should come right off, and then you can get @ the belt – if not then the top cover will come off and then you can serv it from the top if needed. Then you can lift up the one end of the Hoover brushroll and then slide the new belt on to the pulley side of the brushroll and then use a belt puller or a screwdriver with a hook on the end and then pull the belt onto the motor pulley. Then track the belt in a straight line. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 07, 2008
Hoover windtunnel
Hello--How about the Flat belt? That would be my next step...then, if it's still not turning, perhaps the beater/agitator bar's bearings are the culprit...calling for a new beater bar /agitator.
Hope this helps--
Aug 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater bar isn't working
Sounds like a broken belt. Unplug it flip it over and look at the bottom there is a cover over the bottom and the beater bars look for screws or levers to remove the cover then replace the belt. it goes around the beater bar and a drive shaft. check HERE for a manual and belts.
Jun 23, 2011 | Hoover Company Wind Tunnel U53019 Upright...
How do I install a hoover windtunnel vacuum cleaner belt. The bagless one,.
First, take it outside or to the basement. This can get messy. Turn the vacuum cleaner upside down. Remove four 1-1/2" self-tapping screws that hold the bottom cover in place (where the beater bar is.) Remove this and you will see where the belts go; one from the beater bar to a grooved wheel and one from a bowed wheel to a metal spindle way in the back. The beater bar will lift right out. Be sure to clean the threads and pet hair while you're at it.
Mar 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Turbo EmPower 4600 and the roller will not turn when we turn on the vacuum. The vacuum is fairly new, and hasn't seen too much use, but now the roller won't turn, so it's not picking...
The beater belt is broken. There are 4 phillips head screws on the outside (2 on top of the base on either side of the upright, and 2 on the front edge on the underside of the base near front edge). and 4 phillips head screws on the inside (holding the guard cover over the beater bar). The belt is about $3 (part number 38528040). Take out the beater bar and put the new belt around it. Then put the other end around the metal bar and stretch the belt taut as you position the beater bar back into its channel slots. Replace the guard and top cover and you should be good to go...
Jan 23, 2010 | Hoover Vacuums
Beater bars won't turn
It is a really simple and cheap fix! All you need to do is replace the belt. You can get a replacement belt here:
Hoover Windtunnel Belts
Jan 10, 2010 | Vacuums
Replacing a belt Hoover wind tunnel
You will find four screws under the bottom cover. remove these. remove the beater bar, loop new belt on bar on pulley area. install the bar and then pull the belt over the motor shaft. re-install cover.
Oct 05, 2009 | Hoover Vacuums
Hoover Elite Rewind
Something's rubbing. It is probably the beater bar rubbing against the base plate. Remove the base plate and check that your beater bar is back in the sockets of the vacuum frame correctly. If they get installed a bit off, it'll make a LOT of racket. Check it out!
Best regards, --W/D--
Aug 05, 2009 | Hoover Elite U5061-900 Bagged Upright...
How do I change the belt on the motor?
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
262 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
