We have an internet in the cable but we don't have wireless on the router.
    Scholar:
  • 174 Answers
Attach a wireless access point to the router and enjoy wireless internet
Posted on Jul 05, 2008
Plugged the router`s LAN cable to a modem - wifi works but not connecting to the internet. I don`t have the cd with me for auto set-up.
You need to contact your Internet Service Provider for the Internet setup configuration and then configure your router.
Apr 04, 2013 | D-Link Xtreme N DIR-655 Wireless Router
Want to connect to internet through a wireless computer and when I try the site wants a security code and I don't know the code or where to find it
Is it asking you for wireless network key?
You need to check the wireless settings of your router.
Connect one computer to the router with the Ethernet cable.
OPen the setup page of the router and check the wireless settings of your router.
Dec 12, 2011 | Cisco Linksys RangePlus Wireless Router...
The protocol has been switched to 802.11 and needs to be returned to 802.11b. How can we do this with none of our computers able to talk to the router without internet access?
I assume you mean your router has been switched to 802.11G ONLY traffic and your network cards only support B. Only solutions that come to mind is either try using a ethernet cable to directly connect to the router and then change settings. Or try resetting the router by removing power cable then holding down reset button.. I don't recall but some software revision might have wireless on by default. The router would be named WRT54G by default with no encryption. Keep in mind resetting the router will turn all the settings to default including admin password.
Nov 16, 2011 | Linksys Wireless-G WRT54G Router
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
I need to install the router but the disk got broken.
You don't really need to install the router just for you to use it to your pc. What you need to accomplish is the setup or the configuration of your linksys router so that you can use either wireless or ethernet cable connection. You need the information from your internet service provider the internet connection type of your internet whether it is DHCP or PPPOE so that you can set it up on your router. You can use this link for wireless setup - http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
Aug 22, 2011 | Linksys Wireless-G WRT54G Router
I have a D-Link DSBroadBand G ADSL2+router. I cannot access the internet with the ether cable plugged in. I can access the internet via wireless and the ethernet cable with a laptop. I am able to access...
I suspect that your ethernet adapter has been made 'not enabled', but can't explain how to check it since I don't know which version of windows you're running. If you can get to the Device Driver panel, you can change it there...
May 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Jun 28, 2009 | Belkin (F5D7230-4) Router (587009)
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
