Question about Canon BJC S450 InkJet Printer
Canon S450 not responding
Flashes green once than 6 times orange. I've taken out my old ink and added new ones, then I cleaned the ink cartridges and it's still flashing 6 x orange then once green.
Maryse
  • Dennis Aug 19, 2008
    We have the same problem as mllent and bustfen. We tried the solution and we still have one green blink and six orange blinks on canon S450.
Hi folks,
the "normal" reset may not solve the problem with SIX yellow flashes at canon s450, because this means that not "your waste-ink absorber wants to be changed", BUT: your print head carrier (this is the device which is sliding to an fro) is either damaged or : TOO OLD ! With Canon s450, the carrier has a built-in sort of timecounter, and after approximately 18 Months of usage or a bit later, the print carrier deactivates itself - up to now, I didnt' find a way of avtivating it again(service-mode is not possible), and canon helpdesk istself says: buy a new carrier (costs about 45,-EURO in Germany)..
G:H:, Hannover, Germany
Posted on Sep 25, 2008
    Scholar:
  • 49 Answers
Try resetting the printer like this
Canon S450 Printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Posted on Jul 06, 2008
I have just added new ink and the light is now blinking green then orange, what is wrong please
Must be your printer's ink should be reset.
Here is how:
1. Power off printer
4: Continue to hold POWER & Press RESUME twice then release both power & resume
5: When the indicator lights steady, press RESUME three times. The indicator should be orange.
6: Press Power to set data
Nov 20, 2010 | Canon BJC S450 InkJet Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
Good Luck, I hope this helps?!
Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Canon iP1800 not recognising cartridges
5 flashes says the printhead is not installed properly, you may need a new printhead,
Jul 27, 2009 | Universal Office Ink Tank Cartridge for...
Canon PIXMAR MP150 E5 problem
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-28
Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon S450
From what I can tell the 6 orange lights indicate a print head failure. Why the print head has failed is another question maybe too old (I've read somewhere that they only operate for a fixed amount of time), maybe printed enough pages (somewhere else indicated that they only print a fixed number of pages). The solution is to replace the printhead (not just the ink tanks).
There is no way to know which print head needs replacing, so unless you have a spare one you will just have to choose which to change, and if you get it wrong try the other one. It appears to be an expensive way of solving the problem (but I have just found it cheaper to buy a print head which comes with 3 tanks than to buy 3 separate tanks!).
Paul
Nov 19, 2008 | Canon BJC S450 InkJet Printer
Canon BJC 3000 does not print - 6 orange 1 green
Clean the connectors located on the Printhead and the Printhead Carrier... It solved the problem in my case...
Nov 11, 2007 | Canon BJC 3000 InkJet Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon S450 printer not responding
NO BJ Cartridge Orange 6   Re-install cartridge or replace ityou probably don't have the ink cartridge installed correctly. make sure it is pushed and seated properly.
Oct 14, 2007 | Canon BJC S450 InkJet Printer
Canon BJC S450 InkJet Printer Logo
260 people viewed this question
old marine
old marine
