Computers & Internet Logo
Posted on Jul 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have dell Inspiron 6000 laptop computer which has a charging probelm. I have to always keep ac adapter connected so it works. Please advise me. Thank you. Vinay Shah
Matson Kurian
Level 2:
Scholar:
  • Expert 175 Answers
  • Posted on Jul 05, 2008
Matson Kurian
Expert
Level 2:
Scholar:
Answers
175
Questions
Helped
84861
Points
416
The problem you are facing is battery drain out, the cells in the battery are not capable to get charged of to give charge and they have to be replaced - So my advise is to replace the battery and get a new one. Contact dell or local sales office in your nearest area. Also compatible model batteries are also available.
tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 • Computers & Internet
2answers
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
2answers
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
4helpful
5answers
New Dell battery, new AC adapter(not Dell). Won't charge battery
Dell uses a proprietary SMBus protocol over the center pin to communicate the type and power capability of the attached adapter. The laptop uses this information to determine if it can charge the battery without browning out the motherboard. If you use a knock-off power supply that doesn't communicate properly (or at all) over SMBus, then the computer will complain and won't charge the battery. Sorry, Dell has us all right where they want us. Find a used actual Dell adapter on eBay for $20 if you can.
2answers
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
1helpful
3answers
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
2answers
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Grand Canyon Tech
Grand Canyon Tech
