Question about Refrigerators
Water/ice dispenser all the ice has been removed from the hopper and it still does not work. any other problem beside the motor? could it be a solenoid? how would one change the motor? will check the water line if frozen.
  • 58 Answers
It is possible for it to be the solenoid, as for removing the motor you would need the users guide to tell you specifically, as for the ice problem is the door from the hopper and the schute that the ice goes through stuck?
Posted on Jul 05, 2008
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice maker not working
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
Dec 26, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool GS6SHAXLB03
IF YOU REQUIRE A MOTOR CHANGE FOR THE ICE DISPENSER AS A WHIRLPOOL AGENT IN SOUTH AFRICA TO MY KNOWLEDGE THE MOTOR SITS BEHIND THE IS HOPPER.REMOVER THE HOPPER AND IT WILL BE VISIBLE.GOODLUCK.MOHAMED
Sep 10, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
THE ICE CUBE DISPENSER 0NLY SHOOTS CRUSHED ICE
yes and no ...... there is no real adjustment for it but you may have a sticking solenoid .....OK in the back of the unit remove the hopper and you will see the solenoid loop (white Plastic) in the back wall this need to pull up in order for the unit to dispense cubes. it maybe sticking ....now by moving it up and down a few times with your hand to make sure it is free....next dump all the ice out of the hopper and check the arm thathat sticks out the back of the hopper make sure it is not frozen after that reassby and place a few cubes back in the hopper to see if it is working..Let me know
Feb 16, 2008 | Kenmore 25.4 cu. ft. Side-By-Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
