Question about Belkin Computers & Internet
I had to restore computer settings and my wireless G Notebook card is not working....
    Scholar:
  • 174 Answers
What operating system you had and whether you got a windows based system like xp or vista you have a restore option in your system tool sun the restore and get back to a previous days which everything works fine but in your case i hope you have to check from the wireless switch and the device driver for the wireless card, if status for both are ok check for wireless zero configuration service running under administrator tools /services
Posted on Jul 05, 2008
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
My wireless device has been permanently disabled ive tried everything to get it back up and running but nothing worked. i tryed system restore, virus scan,etc. what can i do?
Welcome to Fixya
Check first if the wireless switch is on. There is a small switch on the laptop which is located infront or at the side of th laptop. Make sure that is is set to On position. Try to reinstall the driver of the wireless card using this link. If same thing will happen after doing this troubleshooting. this means that the wireless card has gone bad. Lenovo will replace it for free if the computer is still under warranty. Lenovo support number is 18774536686 press option 2.
Thank you for using Fixya!
Feb 16, 2011 | Lenovo IdeaPad U550 Notebook
Wireless is turned off???????????????
check the laptop right hand side corner on the edge/side of the laptop there is a wireless switch there try to turn it on.
do system restore from the time wireless was still working.
reseat the wireless card. uninstall reinstall the wireless card driver.
replace wireles card.
Apr 08, 2010 | Dell Inspiron 1525 Notebook
Wireless Card not working
Call the Hp Tech Support for the Paid Motherboard Replacement or now time to look for a NEW LAPPY!!!!!!!!!!!!
Feb 21, 2010 | HP Pavilion dv6000z Notebook
Got my brothers old comp, reloaded windows now wireless wont work
Did you install a retail version of Windows? You should have used the restore disc that came with the laptop when you purchased it. That will solve driver related problems if your wireless card is okay.
Check Device Manager if wireless card is still there.
If you install a retail version of Windows, check the support website. Check the wireless card's manufacturer and contact that manufacturer so they can give you the driver for the wireless card.
If you install a retail version of Windows, installing the driver from the support website might not work.
If you used the recovery disc that came with the computer, it should work.
Jan 30, 2010 | Toshiba Satellite 5105-S501 Notebook
Computer crashes
A few things can cause this.
  • Shorted wireless card
  • Weak power plug/connection
  • Weak regulator (inside the computer)
  • Hardware driver issues. You should get a blue screen
Having done a restore eliminates the bad driver really. So we should expect one of the others. If it is a weak power supply, connector it should shutdown when using the cd drive
Try another wireless card if possible.
Jan 24, 2010 | Gateway 4542GP Notebook Computer With...
Wireless will not work in my panasonic cf50 after running restore
You need to download the driver in order to get it to work. Suggestions are using the ethernet connection if possible, or by whatever other means you used to post this message and download the driver for the wireless network card. If you used a secondary computer to download the driver, use a jump-drive/pen drive/thumb drive/memory card/etc, to transfer to this computer.
Jan 10, 2010 | Panasonic Toughbook 50 Notebook
I restored my home computer and the Internet will not work on the desktop but it works on my laptop
The desktop computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | Linksys Wireless-G Broadband Router
Wireless not working properly. i want to pc restore it.
you need to try a restore the IP address or try to make a new IP add from your net work card to make it new..good luck
Sep 19, 2009 | Gateway M-6335 PC Notebook
Cannot get on the internet via wireless
Ah okay thats good news, trying to connect indicates your router is having a hard time giving you wireless nic an IP address, I would login to your router as admin, and restore the router to original manufacturer setting, then redo your wireless settings, and try after that, if its still no go, your wireless nic may of gone bad, but honestly i doubt that, from what you have described so far.
Apr 02, 2009 | Acer Aspire 7720 Notebook PC
Computers & Internet Logo
23 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
