Question about NetGear RP614 Router
I connected my netgear but it does not connect
  • Glen Michaelson May 11, 2010
    What type of internet service do you have? DSL, Cable, Clearwire, Etc. Please provide Type of Internet Service and any other details you have.
    Kind Regards,
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
From the above configuration, please check if you can now access the Internet.
Posted on Jun 02, 2009
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
I have a Netgear WPN 111 dongle on a stand alone PC. It worked with my Netgear G router. I have now changed to a Netgear Router N300. My Laptop connects as does Iphone and Ipods but the Netgear dongle...
As u have upgraded ur router setup ..
And u have tried all possible troubleshooting steps..
Please upgrade the adapter drivers using
http://kb.netgear.com/app/answers/detail/a_id/12520
And after upagrading the drivers ,
Uninstall the adapter and reinstall it ..
I hope it will be connected ..
Jan 07, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
NetGear RP614 Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
