IE"
Water inlet error. Cause : Correct water level (246) is not
reached within 8 minutes after water is supplied or it does not reach
the preset water level within 25 minutes
Ensure your taps supplying the washing machine are turned on.
"UE"
Imbalance error. Cause : The load is to small, the appliance
is tilted, laundry is gathered to one side, non distributed things are
put into the drum.
Move the washing around inside the washing machine to create a more
even distribution of weight
"OE"
Drain error. Cause: not fully drained within 10 minutes
Check there isn't a kink in your drain hose, ensure the filter is clean,
the drain hose can become clogged with sludge, sometimes a hot wash with
1/2 a cup of vinegar will remove this sludge
"FE"
Over flow error. Cause: water is overflowing (water level
frequency is over (213) When FE is diplayed the drain will pump out
automatically.
"PE"
Pressure sensor error. Cause: the sensor switch assembly is out of order.
"dE"
Door open error. Cause: door not all the way closed, loose
electrical connections at door switch and pwb assembly.The door switch
assembly is out of order. Gasket on door maybe creased in.
Try opening and closing the door, sheck to see the gasket isn't jamming
"[-E"
Heating error. Cause: the thermistor is out of order.
CE
Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited.
LE
Locked motor error. Cause: The connector (3-pin), male,white)
in the motor harness is not connected to the connector.
(3-pin,female,white) of stator assembly. Or the electrical contact
between the connectors. (3-pin,male,white) in the motor harness and
4-pin,female,white connector in the main PWB assembly is bad or
unstable. Or the motor harness between the stator assembly and main PWB
assembly is cut (open circuit) Or the hall sensor is out of
order/defective.
bE
Ball sensor error. Cause : Loose ball sensor connector,ball is
out of order. This is displayed only when the start / pause button is
first pressed in the OC test mode.
EE
(EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode.
PF
Power failure. Cause : the washer experienced a power failure.
E1
Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Sorry to read about your problem, I hope this helps you out.
IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on.
"UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
"FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically.
"PE" Pressure sensor error. Cause: the sensor switch assembly is out of order.
"dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming
"[-E" Heating error. Cause: the thermistor is out of order.
CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited.
LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode.
EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode.
PF Power failure. Cause : the washer experienced a power failure.
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
