Can't move cassette carriage.
My carriage motor seems to be under the cassette carriage. How do I get to it? My vhs tape is stuck.
  • 1 more comment
  • savvychris Jul 08, 2008
    Front view
    Right side
    Left side
    Top view
    Hi Shuttle83,
    Here are the photos you asked for.
    I think the carriage motor is under the cassette carriage itself. I thought the gears you can see in the Right side photo operated the carriage, but I can't get them to move.
    I have no documentation -- the VCR is about 10 years old.
    Thx for any help you can provide.
  • savvychris Jul 21, 2008
    I have checked all around it and can't see or feel anything that is the gear lock/release. I'm not even sure what I should be looking for.
    Genius:
  • 1,139 Answers
Hello savvychris
If you can not get to the carriage motor, can you get to the one of the gears attached to the motor or the carriage gear itself. either of these should allow you to release the carriage.
Can you post some pictures of the carriage, this includes front, top, and side shots? what I am looking for is a way to advance the main motor forwards and thus release the carriage locking system.
If possible, if you have the technical documentation, send me a copy of it, I might be able to figure out what is going on for them.
Thank you,
Shuttle83
Posted on Jul 05, 2008
  • Henry McKelvey
    Henry McKelvey Jul 09, 2008
    There is a gear lock on this system, it's purpose is to hold the loading and unloading gear assembly in place while the motor spins the video head drum. There has to be an access point to get to the carriage drive motor. Once you find the access point begin to turn the motor this will lift the carriage and eject the tape. I'll try to find documentation for this issue.
  • Henry McKelvey
    Henry McKelvey Jul 10, 2008
    Try this, look at the sides of your carriage, and tell me if you see a gear or pulley connected to a series of gears, these would be the most likey ones to be the one to turn to release the carriage.
    Let me know if you are able to do this.
    Thank you,
    Shuttle83
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
Tape seems to be stuck to itself, I can't free it up
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Sep 27, 2009 | Panasonic AG-1330 VHS VCR
Vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Jul 21, 2009 | Televison & Video
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Apr 16, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Tape is stuck and I don't know how to get it out.
another way to eject tape is to turn the eject motor by hand in the direction that ejects the tape.
Feb 14, 2008 | GE VG4267 VHS VCR
Tape stuck in VCR
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
Regards,
Eagle
Oct 19, 2007 | JVC HR-J461MS VHS VCR
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
Stuck tape
If you haven't already done so, don't get overly forceful to avoid bending or breaking something. Often the cassette carriage mechanism is gear driven, and by moving the gear one direction or the other will unload the tape. You may need to disassemble the machine further to gain access to the drive mechanisim. Sometimes the carriage mech. can be entirely removed from the VCR by removing the attachment screws. Other times, these screws are made inaccessible by the tape itself. Look down on the right side of the carriage. If you do remove the carriage, mark the gear positioning first! as the gears must be positioned back exactly as they were from the manufacturer. You might need to employ the services of a technician if things are complicated.
May 26, 2007 | Panasonic AG-DV2000 Mini DV VCR
Open Questions:
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
