Question about Garmin eTrex Legend Cx GPS Receiver
Screen blanks out
I have a problem with my unit in that the screen goes blank and a blue line runs down the screen. The only way I can get it to go again is to unplug a battery and then turn it on. Sometimes it goes out again quite quickly, other times it will stay on. Any comments or solutions to this problem????
  • 3 more comments
  • jeannieDBM Jul 10, 2008
    We have about 15 Etrex legends in the field and all have had the same problem. Suddenly the screen will go blank and a blue line goes down one side. We have been able to pull the batteries out, put them back in and continue on with no problem. We call it the "blue line syndrome." A solution would be great. I haven't found anything on Garmin's website about this problem.
  • NITRAM_KONH Jul 29, 2008
    I have a legend cx, which screen blanks out whenever I attach it to an USB cable (which is already attached to a computer , Mac or PC). This behaviour started after I updated the firmware from 2.9 to  version 3.00.
    I am stuck with this, because now I cannot even try to go back to firmware version 2.9..
    After the screen going blank, I can unplug the USB cable and pull out the batteries, put them back in and the device is starting up normally.
    What firmware versions are you using on your GPS devices ?
  • coffmans Sep 24, 2008
    I am having the same problem with about 8 of our units. Finding a solution would be great!
  • dennyof Sep 26, 2008
    have had this thing for about 3 years with no problems ... last time out sreen goes blank and blue line occurs left or right side. R&R batteries usually corrects problem temporarily ... not always
  • Anonymous Sep 30, 2008
    Have the same problem on about 30 receivers. It is especially frustrating when dealing with middle school students who encounter the problem in class. I wish Garmin would come up with a solution or a reason as to why it happens.
  • Garmin Master
  • 638 Answers
Please go to the Garmin website and update the internal software in your GPS unit. A new satellite was launched in 2008 and is causing problems once your unit locks onto it. In the meantime, you can go into setup and disable WAAS. That will fix your problem temporarily. Do the update and see if that fixes this problem. If it does, please come back and rate our solution.
Posted on Jan 08, 2009
Line with bubbles on blank screen
holding the power button down until the unit goes off should do the trick.
Feb 12, 2014 | Toshiba AT200-101 ANDROID TABLET
I get a flash of blue screen when I power on the set.
I have the same problem.
"I get a flash of blue screen when I turn on the LT 30HV. Then the screen goes blank."
Jan 10, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Blank screen with a black line down the middle.
Due to a new satellite launched this year, the WAAS is affected. Disable the WAAS, go to Garmin and download the latest software version FOR THIS UNIT. Install, enable WAAS and you should be good to go.
Nov 23, 2008 | Garmin eTrex Legend GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Garmin eTrex Legend Cx GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
