Question about LG Goldstar LD65EL Dehumidifier
Front panel removal
Please describe more tips for front panel removal. I removed the 2 screws at the bttom of the front panel. Can't find tabs. Thx
  • eknfei Jul 06, 2008
    Excellent! I am back in business...did not know that there were folks out there with solutions to problems like this. Thank-you
    Novelist:
  • 121 Answers
You should see the tabs near each corner on the top and near each corner on the sides up towards the top. What I recommend is pull out slightly where you removed the screws. Then when you look closely you will be able to see the tabs. Once you see the tabs you can compress them with a small flat head screwdriver.
Posted on Jul 06, 2008
  • Justin Jul 07, 2008
    I am happy to have helped. Glad to hear you got it back in business. Were the coils pretty dirty?
My Humidifier is 2 years old. It worked fine and now there is an "EC" code on panel
Unit malfunction. Dehumidifiers are designed to function within specific temperate ranges, usually between 50 and 80 degrees. Make sure that the ambient temperature of the room is within the range of your dehumidifier. Try not to run it continuously.
Jun 06, 2015 | Midea Westpointe 50 PT White Electronic...
Model # 5641 dehumifier- how do you remove the cover to oil the fan?
Pull the humidistat dial off. Remove two screws on the bottom of the front panel. Pull the panel off from the bottom. There are two tabs on the top that will come out when the panel is rotated approximately 45 degrees. There are two oil ports on the top of the motor. Reverse the process to rerassemble the dehumidifier.
Sep 24, 2011 | Kenmore 54501 Dehumidifier
How do you get the front grill off?
Remove water collection bucket. Remove two screws now visible (previously covered by top edge of bucket). Front panel now has to be flexed a bit on the side to release it from the metal side panels, near the lower portion of the front panel, then panel swings up and un-hooks from top.
Mar 01, 2011 | LG LHD45EL Dehumidifier
Compressor and fan working but no water
Take the bucket out and remove the two (black colored phillips head) screws at the bottom of the front panel, just above where the bucket was. Push the bottom of the panel to the side a bit to release the retaining tabs from the metal side panels and pull the bottom of the panel forward to remove the panel from the top tabs, leaving wires attached. Put the bucket back in place and observe the coils while compressor and fan run for several minutes (5 to 10 minutes will do). If coils do not get cold, or only get cold over a small area, you have a refrigerant leak. A refrigerant leak is not economical to repair. Most dehumidifiers have a 5 year sealed system warranty, so round up your receipt and call LG with the model and serial number (located on a sicker behind the bucket) to get an exchange unit. Going from memory here, but I think you can reach LG at 1-800-256-0000.
Jan 25, 2010 | LG LHD45EL Dehumidifier
I am trying to clean my coil to possibly help improve water removal. How do I get the front piece off the machine I have removed the two screws but still cannot pull it off.
After you remove the two screws, you just have to pull up on the front panel (gently). Use the vent slots for finger holds. I just did it 10 minutes ago.
Jun 27, 2009 | LG LHD45EL Dehumidifier
Water leaks around the bucket even the bucket is in place-bucket collects a little bit of water
It sounds like you need to check the drain under the cooling section. It can fill with dust, lint, cat hair, spiders, etc. and prevent water from draining into the bucket. First, unplug the unit. Don't do anything with AC power present. Then, remove the 2 screws under the front panel where the air filter slides up in and pull off the control panel. There are "snap" latches in the plastic near the top that can be (are) hard to undo, so be careful. You might want to have work gloves on because of sharp edges. Prying with a screw driver will cause permanent dents in the plastic. Also, there is a small, sleeved bunch of wires that goes up the left side to the operator buttons and display. Be careful not to damage it and the circuit board it goes to. Set the front panel aside, wire attached. There is no need to disassemble any of that. The drain is a small 3/8" hole in the black plastic floor of the cooling area at the front, right side. It seems to have a fitting for a hose that feeds through to the back of the unit. Clean any foreign material from it and everything else. Test it, with the bucket in place, by pouring some water in, if you want to. Then clean the dust off of everything so it looks new. Don't get the circuit board wet. Re-assemble, being careful with the front panel wire so it is not pinched and does not prevent easy removal/installation of the filter, and it should be OK.
Aug 17, 2008 | Comfort-Aire BHD-501 Dehumidifier
Slight beep but no action/can't get the back off
I had the same problem (minus the cover issue) . To get the cover off, take off all visible screws. Slide a small screwdriver into the space between the back and the side cover. You will see a slight opening where the tabs fit in, you will need to carefully pry the tabs out. However, most likely your problem is with the front panel. You take the front panel off much the same way. 2 screws are concealed by the bucket. I had the same beep no display, thought it was the main pcb, which I ordered and installed. That did not fix it. I cleaned the display pcb, and jiggled the buttons, that seemed to fix it. I think the button to increase the humidity was stuck closed, as I could replicate the problem by holding that button down and then plugging in the dehumidifier. I would start by cleaning or replacing the front panel pcb, which is about $14.
Jul 28, 2008 | Kenmore 54701 Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Dehumidifiers Logo
176 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
