Question about Danby Designer DAR1102W Refrigerator
Fridge getting warm, defost not properly working...
The freezer part is not defrosting correctly and ice is accumulating. The fridge part is just not as cold as it used to be. Last week I started to notice the fridge part getting some water leaked inside of it.
What do I do? How do I fix this problem? I mean, I'm afraid to eat my food without getting sick, it's going to spoil.
  • DavemanX Jul 05, 2008
    Also noticed there is little to no cold air coming into the fridge part at all now.
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
How to fix freezer from icing up on back panel
Faulty defrost I suspect. Could be thermo sensing transducer . Hard to fix as you need to almost defrost fridge before repair man arrives so he can test this transducer works properly when it is cold.
Jun 24, 2015 | Refrigerators
Rb215labp Samsung fridge with freezer on bottom isn't working correctly. Fridge got cold after I defrosted it but only last 24hrs or so and keeps accumulating frost/ice on the back. Freezer doesn't hardly...
This is a twin cool unit. refrigerator works independently from freezer unless compressor failure so compressor is not the problem. you may have a defrost problem or an evaporator fan failure in the freezer easy way to check open door hold the door switch and listen for fan draft if you hear it is good is not you have a bad fan or a bad door switch. the refrigerator has a defrost problem usually is the sensor you try that the other thing can be the heating element but rarely goes bad.
Amazon com DA32 00011E Amazon com DA47 00095E
Dec 20, 2014 | Refrigerators
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
May 29, 2012 | Hoover HCA390FFK Bottom Freezer...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Freezer works fine on my Maytag side-by-side refrigerator, but refrigerator is not cold enough, there is is ice accumulated inside the vent between the freezer and the frig., specially on humid days.
Defrost your fridge with a blowdryer in the freezer after you remove the freezer back panel. Get the ice out of your exhaust pipe going to fridge. Your evaporator fan should be running, either your defrost heater is bad or your defrost thermostat is bad. I ussually replace both. Good luck rate me if I am correct.
Aug 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Danby Designer DAR1102W Refrigerator Logo
407 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
