Question about Panasonic PT-51HX42 51" Rear Projection Television
TV not staying on
When I turn on tv the pictures starts coming up darker then normal and then tv shuts down. The little red light left to power button blinks 3 times, then a pauses and then blinks 3 times again etc...
Is there a quick solution to this?
Ingrid
  • 3 more comments
  • Anonymous Sep 24, 2008
    I called the help line and they said to call a tech...
  • skcsward Sep 30, 2008
    same exact problem. Did you figure out the issue?
  • Anonymous Jan 08, 2009
    Same problem. Turned TV on. It stayed on for just a minute and now only seconds. Then it just turns off and the power light blinks 3 times, pauses and blinks again. I noticed a burning smell and unplugged the TV.
  • Anonymous Feb 25, 2009
    same problem, now, the tv cannot be even turned on at all, just the red light blink for several times.
  • HectorB34 Mar 01, 2009
    My Panasonic color projection system does not turn on at all. The LED light flashes 5 times and pauses for 5 seconds before repeating the cycle. Anyone knows what this means for model# PT-56WX53G?
I called a tech and it was a convergence issue. It cost $375 to fix.
Posted on Oct 03, 2008
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
TV turns itself off.
if you now how to used soldering iron , resolder your tv
Oct 22, 2008 | Televison & Video
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
Apr 30, 2008 | LG RU-44SZ61D 44" TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Jan 05, 2008 | Televison & Video
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Panasonic PT-51HX42 51" Rear Projection Television Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
