Question about Kitchen Ranges
Set coil burner at medium heat it goes vto high by itself.
  • 413 Answers
Replace the associated switch/control for this burner.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Heat problem, cannot sear.
You could have a bad regulator. You can purchase them a most places that sell grills
Apr 12, 2010 | Weber Genesis E-310 Gas Grill
Burner works on high (9), loses heat at medium (5)
The control is bad. I assume the burner worked on the other side?
eric
Jul 03, 2009 | Kitchen Ranges
Stove top
YOUR SWITCH IS BAD FOR THAT BURNER REPLACE THE SWITCH AND YOU WILL BE GOOD TO GO
Jan 07, 2009 | Frigidaire FEF351C Electric Kitchen Range
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
Burner doesn't simmer
Switch that controls that burner is bad and needs replacing
Nov 03, 2017 | Cooktops
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
