Question about Maytag Atlantis MDE7400AY Electric Dryer
Open up the panels and remove the igniter
I need the step by step instructions to remove the igniter.
  • 943 Answers
Hi thanks for the question you must remove the front panel 2 screws at the bottom remove the panel igniter on left 1 screw holds it in place disconnect power replace igniter thanks the appliance doc
Posted on Sep 18, 2008
How to set new key fob?
Google - for the win!
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Oct 06, 2012 | 2002 GMC Yukon Denali
How to syncronize 2 keyless remotes for 2000 gmc sierra
Here is the way to do it.
1. Close all doors
13. Test remote(s).
May 25, 2012 | 2000 GMC Sierra
Hi I m trying 2 program my remote on my 2001 Pontiac Aztec
Obtain all remote transmitters for this vehicle.
1. Close all doors.
2. Insert key into the ignition cylinder but do not turn it.
3. Press and hold the Unlock button on door lock switch on drivers door.
Hold until instructed to release.
4. Remove key from ignition and then insert key into ignition without turning ignition cylinder and remove key.
5. Insert key in ignition a third time and leave key in ignition. Do Not turn ignition.
6. Release door lock switch on drivers door panel.
A Chime will sound 3 times indicating that you are in programming mode.
7. Press both the Lock and Unlock buttons on the remote up to 30 seconds.
A chime will sound 2 times if remote has programmed successful.
8. Repeat step 6 if you are programming additional remotes.
9. Remove key from ignition to exit programming mode.
NOTE: If you are having trouble getting this procedure to work, we have found that some vehicles need step 3 to be done before step 2
Aug 02, 2011 | Pontiac Aztek Cars & Trucks
Instructions how to step by step replace ignition lock cylindor for an 1999 oldsmobile intrigue
1999 Oldsmobile Intrigue
IGNITION SWITCH AND LOCK CYLINDER REPLACEMENT
1. Disconnect battery
2. Disable Supplemental Restraint System (Airbags)
3. Remove traction control switch from rear of center console plate
4. Open console lid and remove screws at front of console
5. Pull console plate up to release clips and slide over shifter
6. Pull rearward to release clips retaining instrument panel accessory trim plate to instrument panel
7. Remove screws attaching radio to instrument panel
8. Disconnect electrical connectors and remove radio
9. Take down instrument panel hush panels and disconnect courtesy lights. Remove hush panels
10. Remove knee bolster and knee bolster bracket from driver's side below steering column
11. Remove screws from IPC trim plate
12. Pull out instrument panel cluster trim plate to release from retainers
13. Remove trip odometer and reset switch from IPC trim plate
14. Remove IPC trim plate
15. Remove screws from IPC and pull IPC out
16. Disconnect electrical connectors from IPC and remove IPC from the instrument panel
17. Disconnect ignition switch connectors
18. Turn ignition switch to the ACC position and remove park lock cable from ignition switch
19. Turn ignition switch to ON position
20. Depress and hold locking tab on right side of ignition switch with a small, flat-bladed screwdriver and pull ignition lock cylinder from ignition switch
21. Remove ignition switch bezel from ignition lock cylinder
22. Remove screws attaching ignition switch to bracket
23. Remove ignition switch through the IPC opening
24. To install, reverse procedure
Apr 04, 2011 | 1999 Oldsmobile Intrigue
My keyless entrey will not work has new battery?
Hi, please try reprogramming the fob using these procedures, and thankd for using FixYa:
Close all doors
13. Test remote(s).
Jan 14, 2011 | 2003 GMC Sierra 1500
I changed batteries in my 2003 GMC Sierra key fob
1. Close all doors
13. Test remote(s).
Mar 06, 2010 | 2003 GMC Sierra 1500
Can't get Blazer into transmitter programming mode
1. Close all doors
13. Test remote(s).
Feb 19, 2010 | 2001 Chevrolet Blazer
I need programming instructions for a 2002 toyota highlander for my remote.
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Jun 30, 2009 | Toyota Highlander Cars & Trucks
I need to mprogram a new remote that I just
. Close all doors 2. Insert key into ignition
13. Test remote(s).
Jun 12, 2009 | 2001 Chevrolet Blazer
Need to re-program 2000 Chev.C3500 key fob need help
1. Close all doors
13. Test remote(s).
Jun 09, 2009 | 1999 Chevrolet Tahoe
Maytag Atlantis MDE7400AY Electric Dryer Logo
47 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
