1993 Mercury Sable Logo
harley Posted on Jul 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 Mercury Sable, white smoke, overheating
My girlfriend just bought this car and it drove absolutely perfect with COLD a/c for the first week, then it started making a sounds kinda of like a clicky-sputtering when the ac was on, i think that is the converter clutch or whatever. but anywho, since then white smoke comes from what looks like maybe under/behind the radiator, and a little behind the block. i dont know if this is from something leaking and burning, it is white smoke. the radiator itsself has some gunk in it, black stuff. i dunno if a dirty radiator would smoke or any reason, but it is also overheating after driving for like 20 miles. any ideas?
  • harley
    harley Jul 05, 2008
    thank you both for your input. i will check out the tail pipe for the smoke. thanks again! very helpful.
  • Anonymous Dec 21, 2008
    I have no heat in my car, Its a 1993 mercury sable, could it be the thermostat?
Steve Allison
Level 3:
  • Mercury Master 5,569 Answers
  • Posted on Jul 05, 2008
Steve Allison
Mercury Master
Level 3:
Answers
5569
Questions
Helped
2000808
Points
16452
All the symptoms of a blown head gasket.
The white smoke is caused by the hot evaporation of coolant that has landed where it doesn't beling (inside the combustion chamber) and the gunk in your coolant is oil and combustion byproducts that have leaked into the cooling system.
The overheating comes from the fact you are currently pumping burned or burning gases into the coolant system - they are hot!
I see a fairly expensive head gasket replacement and possibly a surfacing job to get the head flat again if it has warped.
The actual headgasket is cheap and if bought as a set, should include other gaskets that will need replaced after the head is removed since there will be a number o things in the way.
If you consider doing it yourself, buy a Haynes or Chilton service manual and study it first.
Anonymous
Level 3:
  • Master 405 Answers
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
261237
Points
1263
Good Day,
White some indicated that coolant is burning off. It could just be a simple leak which is burning off of the hot motor. It could also be a bad head gasket(probably what you don't wanna hear), One indication that it is the head gasket is white smoke coming out of the exhaust, this happens as coolant gets into the oil and is burned off then exhausted out the back. Possible causes for the overheating include, low coolant, coolant leak, thermostat, water pump and or water pump belt, or head gasket.
If I were you I would drain and flush the radiator, then fill it with new coolant, and change the thermostat, provided you have no white smoke coming out the exhaust.
hope this helps for now
97 Mercury Sabel overheating and water brown and bubbling out.
Have the head gasket checked, it sounds like it needs replace.
If you need further help, reach me via phone at https://www.6ya.com/expert/andrew_d2df42288260d96e
Overheating
Sounds like you may have a blown head gasket,white smoke is usually caused by this,driving it can cause major damage,best to have towed to a shop.
2helpful
2002 mercury sable overheating
Generally speaking, you can run the engine with or without the heater connected and it should make no difference in cooling the engine.
I wonder if the engine is actually running above 220 degrees.
Do you know where the steam or smoke is coming from ?
It could be a leak rather than actual overheating.
Our mercury sable 1993 keeps overheating
are the cooling fans running? is it loosing water from exhaust or in the oil check these things water is going somewhere
I have a 2001 Bora pd 115bhp engine code ajm... I recently done the head gasket in it and since it has been done the car is hard start from cold. the engine turns over for 10 or 15 seconds before it will...
Sounds like there was more damage present than just the head gasket. Perhaps a crack in the cylinder head. Was it pressure checked? Was the car overheated? The white smoke sounds like coolant leaking into one or more cylinders.
Hi i just bought a 93 mercury sable and i have been driving it for about 3 week. just 2 days ago it started to over heat so i checked the coolant and it was very low, so i add some up to the full line. i...
White smoke is caused by coolant or water coming out the tail pipe. white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
1993 Topaz, 4 cylinder, Automatic. Will not shift into third gear. Transmission was fine until the water pump went out and took it to a shop. After the water pump was replaced, white smoke came out...
it is possible that the vacuum line for the transmission actuator was damaged during the head job
check for wiring harness connections not properly put back together
Over heating white smoke out tail pipe when car frist starts
ok it could be a couple things check and/or change the thermostat if that doesnt work then try to replace the heater core
1993 mercury sable
does the car make a squeking noise when you start it?
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
