Question about Sony KV-36XBR450 36" TV
Sony KV-36XBR450 HELP
My tv which is only six years old has now begun to give me problems. I've read some posts but just want to make sure as personal setting may make a difference. The screen turns black on and off on regular intervals and also the screen or colours are always blurry and not sharp as they should be. Any remedies for the $4600 paper weight would be greatly appreciated!!
Thanks
Morris
  • yo_paisan Jul 18, 2008
    I too have the same problem... I turn the TV on and it sounds like it's coming on, then it turns itself off. Then the red standby light just keeps flashing on and off... At first I would disconnect power from the TV and let it sit, then plug it back in and try it as if it was "overheated" and it would work, but now it just doesn't work at all. I spoke to a local TV repair shop who's been around for 30 years and does Factory Authorized repairs. From my description over the phone they estimated about $600 to fix it.
    I'm torn between the decision of having it fixed or replacing it. It's a very heavy TV to have to get rid of some how... $600 is a lot cheaper than buying a new comparable FLAT SCREEN... sooooo... I dunno...
    Sort of a mixed bag situation...
    --Paul
    Genius:
  • Sony Master
  • 1,689 Answers
You are not going to like what I am telling you.
The problem you are seeing is that the emission of the CRT has decreased to a point where there is not enough beam current, and the drive circuits are shutting down the beam bias to the electron-gun. The emission is at the borderline stage where it is on the edge and that is why it turns on and off. Most likely, as the cathode in the electron-gun warms up enough to reach a high enough emission, the bias circuits will switch on. Then when the emission drops just slightly because of the beam loading, there is a fault detected, and the bias circuits are switched off.
When you see the picture, the lack of sharpness (soft picture) is because there is too low a beam current for the electron beam to become narrow enough to be sharp at its focal point. There are circuits in the high voltage section to control focus, but they cannot go beyond what the beam cannot deliver.
The solution would be to change the CRT. This would not be feasible, and the CRT is no longer available. It will also be expensive to pay the labor to have the CRT changed. It would require a tech with the skills to perform the factory level purity set-up, convergence, pin-amp, scanning, and color temperature set-ups.
The labour alone could cost a minimum of a few hundred dollars. If I remember correctly, when the CRT was available for your model, it was costing over one thousand dollars. There are some strip magnets and rubber spacers that will also have to be replaced. Sometimes there may be some other small parts required. This will add to some extra cost.
In your case if the set is 6 years old, there is no gaurantee of how long it will take before there are other types of failures. Personaly I would not fix this set!
I would suggest to get yourself an LCD or Plasma HDTV to replace your set. Stay with a known brand name, and take the extended warranty. For myself, I would buy only a brand name that the company also manufactures broadcast and industrial TV equipment. This way, you know you will have original design, and high quality assembly in the set. You will get what you pay for.
In a very basic context, if you are going to watch in a dimly lighted room the Plasma is a good choice. If you are going to watch in a room that is lighted most of the time the LCD would be a better choice. Both systems are good. It depends on your preference and they way you will use the set.
Jerry G.
Posted on Jul 06, 2008
Sony kv-36xbr450 36
breakdown in the horizontal, check the c515, c516 and the jungle ic IC206 which get bad.
Oct 27, 2012 | Sony KV-36XBR450 36" TV
KV-36XBR450 input selection problem
Go into the menu on the TV and go to the far right under setup. Select "video label" then select "program". A menu will come up listing the 7 inputs. Make sure that the input you are using for your PS3 is not set to "skip". While you're there, set any of the other outputs you're not using to "skip". Your TV/Video button will only cycle through the ones that aren't skipped. Have Fun!
Feb 01, 2009 | Sony KV-36XBR450 36" TV
Kv-36xbr450 picture freezes or wiggles
Check the cables going in and out of the tcon board if that doesn't fix it replace that board
Nov 25, 2017 | Sony KV-36XBR450 36" TV
Sony KV-36XBR450 36 SCREEN TURNS BLACK ON AND OFF AND BLURRY
Here is a possible repair for your problem. Remember that this is not deffinet.
This does sound like a difficult problem, it might be better to let a repair shop handel it.
Poor contrast and picture disappears in Vivid and Pro screen modes.
Problem was resolved by replacing C210. The capacitor was breaking down under
operation. Important note: capacitors C257 and C248 are in parallel with C210 and similar
failure of any
one of these three capacitors could cause an identical symptom.
C210 P/N 112776011
Jul 05, 2008 | Sony KV-36XBR450 36" TV
Dynex TV Problem
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 21, 2008 | Sony KV-36XBR450 36" TV
My t.v has sound but no picture
i have sony 24"tv they have no picture but having sound.what do you think this problem
Jan 11, 2008 | Sony KV-36XBR450 36" TV
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Sony KV-36XBR450 36" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
