Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking timer light nothing works
Have the 52825 model. Fast blinking timer light; manual says to hit reset but that doesn't work. For about a year I have unplugged and replugged the tv, usually several times, to get it to reset and work for a time. Now nothing works
  • Mitsubishi Master
  • 8,617 Answers
Have you tried the menu and device buttons held in together to activate the led error code feature? Let me know the error code.
Posted on Jul 06, 2008
Mitsubishi TV How do I fix green blinhing light in mitsubishi DLP TV 52825
most likely its a bad power supply. the wd52825 is known for that issue. check youtube for repair videos.
Jan 28, 2015 | Mitsubishi Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a wd 52825 and accidentally hit the system reset button with a stiff brush...now the green light won't stop blinking and won't power up...what are my options?
I found this on the web .... might help ... dont know but it might be worth a try....also removeing the bulb and checxk it
Front Buttons Do Not Work Cause 1
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
Locks up when Device Button Pressed Cause 1
1. Initialize settings by pressing "menu, 2, 4, 7, 0, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings.
2. Initial and reset does not resolve suspect the DM PCB part # 934C116001 .
Oct 31, 2010 | Mitsubishi WD-52825 52" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Blinking green light for Model WD-52825. What
The usual cause is due to the DM not booting up due to failed capacitors. You can get the V26 DM repair kit at www.tvrepairworld.com which contains the replacement capacitors and the CD with detailed instructions.
Dec 20, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
