Electric Fans
Problem for Electric Fans
Generic problem for all Electric Fans
Neutral (white) wire connection
By decaff on Jul 05, 2008
Where does the white wire come from off the electric motor on a ceiling fan.The one I have fell off while I was cleaning it and fell far enough to pull the power wire loose. The black wire pulled loose from a wire nut, but the white pulled loose from a solder joint and was inside the tube between the top of the motor and ceiling mount.The problem is the white wire only runs to a wire nut on the bottom side of the fan for light that it doesn't have,I can't seem to find where the white wire was connected to complete the circuit.
Solution #1
posted on Jul 09, 2008
Not Helpful)
freetek
Rank: Guru
Rating: 85%, 1793 votes
Use caution when dealing with AC, it can be deadly.
The black wire by accepted standards is the 'hot' wire and will measure (when active) 110-125 volts (in the US) to ground or the white neutral wire in a normal household system.
The white wire may have a couple of volts when measured to an earth ground or any green (or green-yellow) wire which is (by standards) connected to earth ground, often via plumbing pipes in some homes, or a visible or buried grounding rod driven several feet into the earth.
The black (hot) wire is the one customarily 'switched.'
I would highly recommend you have a qualified electrician reconnect the strayed wires to protect yourself and the fan.
Was this helpful?
Yes
No
Popular Solutions for Electric Fans
Questions and Unsolved Problems for Electric Fans
Answer
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is... (More)
Answer
Trying to install new hunter 44155c...my old thremostat has diff letters...I have B,G,Y,R,W and... (More)
Answer
My heater's internal thermometer is too sensitive. It shuts itself off after being on for only a... (More)
Answer
I have a ceiling fan and light combination and I am not sure of the brand. It has a remote receiver... (More)
Answer
Installed Hunter 44110 this summer and AC worked great. Just tried the heat and still blows cold... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Fans Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
