SOURCE: Tony Hawk shred board will
i had this same issue try turning off the lights leaving only the light from the tv....worked like a cham for me!
SOURCE: board will not calibrate to
Don't use brand new batteries. Using older batteries makes the sensors less "sensitive". You will have to recalibrate every time you change batteries but at least you can use your product this way.
SOURCE: Cannot calibrate Tony Hawk Shred
I had the same problem. I solved it and got the board to calibrate immediately when I replaced the brand new batteries with used batteries. Brand new batteries apparently make the lasers very sensitive. You have less sensitive sensors with the used batteries. I just took some AA's out of my cable remotes. The game is awesome once you get it calibrated. I felt your pain for an hour or so.
